Trouble Finding KLV Data Stream in Video File
dabbler
We have gotten the IPP UMC software to recognize the mpeg-2 data stream in a videofile that contains both a video stream and a KLV data stream. However, only the video stream is recognized as a stream. Is there a way to recognize and split out the KLV data stream?
Thanks for any help you might provide.
dabbler
PaulF_IntelCorp
Hello "Dabbler":
The premier issue you posted indicates that you were successful at implementing changes to the UMC code to support KLV. Happy to hear that you were able to make that work. You indicated you'd like to share that code. If you wish, you are welcome to attach the salient changes to this forum thread for others to use.
Paul
