6825 Discussions
Trouble Using IMPLIB on 7.0 DLL's to make import libraries for Borland C++ Builder
paulsgauthier
I'm trying to update our Borland Builder app with the latest IPPI 7.0 library (we've been using 4.1) but I can't run implib to create import libraries from the 7.0 DLLs like I normally do. When I run the command:
implib -a ippcore-7.0-Borland.lib ippcore-7.0.dll
on my Windows 7 system implib crashes. No idea why. Same for all the 7.0 DLLs.
implib still works fine when run against the old 4.1 DLLs.
I can't go forward with 7.0 until I resolve this. Any ideas?
Paul Gauthier
Image Softworks
SergeyKostrov
Valued Contributor II
-I would try to do this ona Windows XP
-I would try to use 'implib' from aversion 5.x.x ofBorland C++ compiler
Note: It is a free C/C++ compiler now
paulsgauthier
Sergey: Tried implib from version 5 with same result. Will try to find an XP system.
paulsgauthier
The problem was I had 64-bit DLLs. IMPLIB only works on 32-bit DLLs. After downloading the 32-bit version of Intel IPP, IMPLIB worked fine.
SergeyKostrov
The problem was I had 64-bit DLLs. IMPLIB only works on 32-bit DLLs...
Thanks for clarification. A version with 'LoadLibrary' or 'LoadLibraryEx'functions could be considered instead.
Sergey
