UIC decoder: some problem from Readdata()?
fanguts
Hello: I implemented UIC decoder to my application. A number of decoder's interface has been implemented(such as jpegdec.Init(), jpegdec.AttachStream(), jpegdec.ReadHeader(), jpegdec.SetParams(), jpegdec.ReadData() ).
I can see the program got correct image size, sampling rate from ReadHeader().
In my program final part, I created a data buffer with size (image Height*Width*Sampling Rate). I copy the depressed image data--Buffer().DataPtr() from Readdata() to my buffer, the program is crush. It seems problem from jpegdec.ReadData(). I post my function below, please give some help, thank you all
FunctToReadJPEG()
int i;
int du = 0;
int dd_factor;
int comment_size;
Ipp8u* comment;
Image imageCn;
ExcStatus status;
JPEGDecoder jpegdec;
ImageDataPtr dataPtr;
ImageDataOrder dataOrder;
ImageColorSpec colorSpec;
ImageSamplingGeometry geometry;
PARAMS_JPEG param;
param.nthreads = 1;
param.use_qdct = 1;
param.dct_scale = JD_1_1;
param.color = JC_UNKNOWN;
param.huffman_opt = 0;
param.mode = JPEG_BASELINE;
param.point_transform = 0;
param.predictor = 1;
param.quality = 75;
param.restart_interval = 0;
param.sampling = JS_444;
param.use_qdct = 1;
param.comment_size = sizeof(param.comment);
jpegdec.SetNOfThreads(param.nthreads);
status = jpegdec.Init();
if(ExcStatusOk != status)
return JPEG_ERR_INTERNAL;
CStdFileInput in;
BaseStream::TStatus statusStream;
statusStream = in.Open("c:\\test.jpg");
if(BaseStream::StatusOk != statusStream)
return 0;
status = jpegdec.AttachStream(in);
return JPEG_ERR_INTERNAL;//UIC end
status = jpegdec.ReadHeader(colorSpec,geometry);//got image size 400X100, sampling rate 3 correctly
m_nPlateWidth = geometry.RefGridRect().Width();
m_nPlateHeight = geometry.RefGridRect().Height();
param.mode = jpegdec.Mode();
param.color = GetColor(colorSpec.EnumColorSpace());
param.sampling = GetSampling(geometry.EnumSampling());
jpegdec.Comment(&comment, &comment_size);
if(comment_size != 0)
param.comment_size = IPP_MIN(comment_size,MAX_JPEG_COMMENT_BUF);
ippsCopy_8u(comment,param.comment,param.comment_size);
else
param.comment[0] = '\0';
param.comment_size = 0;
int nOfComponents = geometry.NOfComponents();
if(JPEG_BASELINE == param.mode || JPEG_PROGRESSIVE == param.mode)
switch(param.dct_scale)
case JD_1_1: dd_factor = 1; break;
case JD_1_2: dd_factor = 2; break;
case JD_1_4: dd_factor = 4; break;
case JD_1_8: dd_factor = 8; break;
default:
dd_factor = 1;
else
dd_factor = 1;
JPEGDecoderParams jparam;
jparam.SetDCTScaleFactor(param.dct_scale);
jparam.SetDCTType(param.use_qdct);
jpegdec.SetParams(jparam);
if(param.dct_scale != JD_1_1)
Rect refgrid;
Point origin;
RectSize size;
origin.SetX(0);
origin.SetY(0);
switch (param.dct_scale)
case JD_1_2:
size.SetWidth ((geometry.RefGridRect().Width() + 1) >> 1);
size.SetHeight((geometry.RefGridRect().Height() + 1) >> 1);
break;
case JD_1_4:
size.SetWidth ((geometry.RefGridRect().Width() + 3) >> 2);
size.SetHeight((geometry.RefGridRect().Height() + 3) >> 2);
break;
case JD_1_8:
size.SetWidth ((geometry.RefGridRect().Width() + 7) >> 3);
size.SetHeight((geometry.RefGridRect().Height() + 7) >> 3);
break;
refgrid.SetOrigin(origin);
refgrid.SetSize(size);
geometry.SetRefGridRect(refgrid);
geometry.ReAlloc(nOfComponents);
if(colorSpec.DataRange()->BitDepth() + 1 <= 8)
dataOrder.SetDataType(T8u);
du = sizeof(Ipp8u);
else
dataOrder.SetDataType(T16u);
du = sizeof(Ipp16u);
dataOrder.ReAlloc(Interleaved, nOfComponents);
dataOrder.PixelStep()[0] = nOfComponents;
dataOrder.LineStep() [0] = ((geometry.RefGridRect().Width() * nOfComponents *du+ 3) & ~3);
imageCn.ColorSpec().ReAlloc(nOfComponents);
imageCn.ColorSpec().SetColorSpecMethod(Enumerated);
imageCn.ColorSpec().SetComponentToColorMap(Direct);
for(i = 0; i < nOfComponents; i++)
imageCn.ColorSpec().DataRange().SetAsRange8u(255);
else
imageCn.ColorSpec().DataRange().SetAsRange16u(1 << colorSpec.DataRange()->BitDepth());
ImageEnumColorSpace in_color;
ImageEnumColorSpace out_color;
in_color = colorSpec.EnumColorSpace();
switch(nOfComponents)
case 1: out_color = (in_color == Unknown) ? Unknown : Grayscale; break;
case 3: out_color = (in_color == Unknown) ? Unknown : RGB; break;
case 4: out_color = (in_color == Unknown) ? Unknown : CMYK; break;
default: out_color = Unknown; break;
imageCn.ColorSpec().SetEnumColorSpace(out_color);
int r;
IppiSize size;
size.width = geometry.RefGridRect().Width();
size.height = geometry.RefGridRect().Height();
CIppImage image;
r = image.Alloc(size, nOfComponents, colorSpec.DataRange()->BitDepth() + 1, 1);
if(0 != r)
return JPEG_ERR_ALLOC;
image.Color(GetColor(out_color));
if(image.Precision() <= 8)
dataPtr.p8u = image;
else
dataPtr.p16s = image;
imageCn.Buffer().Attach(&dataPtr,dataOrder,geometry);
status = jpegdec.SetParams(imageCn.ColorSpec(),imageCn.Buffer().BufferFormat().SamplingGeometry());
status = jpegdec.ReadData(imageCn.Buffer().DataPtr(),dataOrder);
after readheader() and readData(), I created TempBuf
and copy the depressed image data imageCn.Buffer().DataPtr() to TempBuf, but program crash
BYTE *TempBuf;
TempBuf = new BYTE [size.height*size.width *3 ];//3 is sampling rate
for (int nY = 0; nY < size.height ; nY ++)
for (int nX = 0; nX < size.width ; nX ++)
memcpy(TempBuf + nY * size.width * 3 + nX * 3, imageCn.Buffer().DataPtr() + nY * size.width * 3 + nX * 3, 3);
Vladimir_Dudnik
memory allocated for UIC Image object may get padded at each row to get 32-bit alignment. The right way to copy pixel data from UIC Image object would be using ippiCopy function for appropriate bit-depth and number of channels. This will require you to get image step (aka pitch) info from UIC Image
Vladimir
