UMC H.264 decoder
Purvin_Pandit
Hi
I have a H.264 bitstream (fields only) with intra refresh (no I/IDR only P fields) + recovery point SEI. The bitstream does not start at frame_num = 0. It starts at frame_num = 201, now after the frame_num wraps and the next time a frame with frame_num = 201 arrive the old frame_num = 201 is still in the Decoded list. Not sure why it is not removed.
This bitstream can be decoded by JM and other decoders. Is there a known issue when a bitstream does not begin with frame_num = 0, has recovery point SEI?
-Purvin
Purvin_Pandit
Digging a little more I found this code in:
bool TaskSupplier::AddSlice(H264MemoryPiece * pMem, MediaData * pSource)
if (NumShortTermRefs + NumLongTermRefs == 0)
if (sliceHeader->field_pic_flag)
pFrame->setPicOrderCnt(m_PicOrderCnt,0);
pFrame->setPicOrderCnt(m_PicOrderCnt,1);
else
pFrame->setPicOrderCnt(m_TopFieldPOC, 0);
pFrame->setPicOrderCnt(m_BottomFieldPOC, 1);
Looks like this is done only for the 1st field (in my case) so it sets the top & bottom POC to be the same. This is causing the problem where the bottom field is never removed. This looks like a bug. Can someone confirm?
Chao_Y_Intel
Purvin,
Would it be possible to attach the test stream? Our expert comments that this is not very clear on what is happeing from the description.
Chao
Purvin_Pandit
Thanks Chao. I will try to get a bitstream to you as soon as I can.
-Purvin
