UMC::H264VideoDecoder problem
danielwang1971
I'mworking for H264 coompression project.I'm testing IPP and I UMC :: H264VideoEncoder and UMC::H264VideoDecoder. I got a problem when decode h264 image using UMC::H264VideoDecoder.
First, I encode imageusingH264VideoEncoder.And I save to disk H264 images.And then I read datafrom disk and Idecode it by UMC::H264VideoDecoder but I got UMC_ERR_NOT_ENOUGH_DATA errorfor first image.Can youhelp me?
Daniel
danielwang1971
My decodefunction like:
BOOL Decode(void* destImage,int destBuffersize,void* srcImage,int srcBufferSize,FrameType type)
if(!Decoder) return FALSE;
DecodeIn->SetBufferPointersr(srcImage,srcBufferSize);
DecodeIn->SetFrameType(type);
DecodeOut->SetBufferPointer(destImage,destBuffersize);
DecodeIn->SetDataSize(len);
if(First)
DecoderParams->info.stream_type = H264_VIDEO;
//DecoderParams->numThreads = num_threads;
DecoderParams->lFlags = 0;
DecoderParams->m_pData = DecodeIn;
Decoder->Init(DecoderParams);
DecodeOut->SetAlignment(16);
DecodeOut->Init(ImageWidth, ImageHeight, UMC::GRAY, 8);
First = false;
Error = Decoder->GetFrame(DecodeIn, DecodeOut);
if(UMC_ERR_NOT_ENOUGH_DATA == Error)
return FALSE;
else
return TRUE;
I got UMC_ERR_NOT_ENOUGH_DATA error.
Thank you so much.
daniel wang
Vladimir_Dudnik
Hello Daniel,
did you try to decode your data with simple_player application from IPP audio-video-codecs sample?
Vladimir
danielwang1971
Thank you your response so quickly,I tested with simple_play.Exe,didn't work,neither.
Here's my Encode function
EncoderParams = new H264EncoderParams();
EncoderParams->info.clip_info.width = ImageWidth;
EncoderParams->info.clip_info.height = ImageHeight;
EncoderParams->info.framerate = 30;
EncoderParams->numEncodedFrames = 0x7fffffff;
EncoderParams->chroma_format_idc = 0;
EncoderParams->profile_idc = H264_HIGH_PROFILE;
EncoderParams->info.bitrate = 5000000;
bool EncodeImage(void* destImage,void* srcImage)
if(!Encoder)return false;
if(First)
Error = Encoder->Init(EncoderParams);
Error = Encoder->GetInfo(EncoderParams);
if(Error != UMC_OK)
return false;
EncodeIn->Init(ImageWidth, ImageHeight,GRAY,8);
//Create the sequence on disk
StreamFile = CreateFile(_T("c:test.dat"), GENERIC_WRITE | GENERIC_READ,
FILE_SHARE_READ | FILE_SHARE_WRITE, NULL, CREATE_ALWAYS,
FILE_ATTRIBUTE_NORMAL, NULL);
if(StreamFile == INVALID_HANDLE_VALUE)
StreamFile = NULL;
First = false;
EncodeInData->SetPlanePointer(srcImage,0);
EncodeOutData->SetBufferPointer(destImage,ImageWidth* ImageHeight);
Error = Encoder->GetFrame(EncodeInData,EncodeOutData);
if(Error != UMC_OK)
return false;
unsigned long len = EncodeOut->GetDataSize();
if(StreamFile)
DWORD written;
if(!WriteFile(StreamFile, destImage, len, &written, NULL))
return false;
return true;
After that,I run simple_player and my decode function, both of them didn't work.
Can your tellme what wrong in my code?
Daniel wang
Vladimir_Dudnik
If you are able to compress your input stream with umc_video_enc_con application (and decode then back with simple_player) you may check encoder application sources to see what is wrong
Vladimir
