6832 Discussions
UMC::ThreadedDemuxer.GetInfo() is not correct if the input is MPEG2 video interlaced BOTTOM_FIELD_FIRST
anonymous210
IPP v6 and V7
If the input file is MPEG PS with mpeg2 video iterlaced BOTTOM_FIELD_FIRST then UMC::ThreadedDemuxer.GetInfo() reports incorrect info. The iterlaced type in UMC::SplitterInfo returned by UMC::ThreadedDemuxer.GetInfo() is TOP_FIELD_FIRST.
I traced the problem to Mpeg2FrameConstructor::GetFrame()
The original code from IPP v6 is:
Status Mpeg2FrameConstructor::GetFrame(SplMediaData *frame)
Status umcRes;
Ipp8u *buf = m_pBuf;
bool bFound = false;
while (!bFound)
// Find and parse sequence header
if (!m_bSeqSCFound)
if (!m_bInfoFilled)
{ // we havn't yet parsed sequence header
while (m_lCurPos < m_lLastBytePos - 3 && !IS_CODE(&m_pBuf[m_lCurPos], 0xb3))
m_lCurPos++;
if (m_lCurPos >= m_lLastBytePos - 3)
return m_bEndOfStream ? UMC_ERR_END_OF_STREAM : UMC_ERR_SYNC;
Ipp32s seqEnd = m_lCurPos + 4;
while (seqEnd < m_lLastBytePos - 3 && !IS_CODE_4(&m_pBuf[seqEnd], 0x00, 0xb3, 0xb7, 0xb8))
seqEnd++;
if (seqEnd >= m_lLastBytePos - 3)
umcRes = ParseSequenceHeader(&m_pBuf[m_lCurPos], m_lLastBytePos - m_lCurPos, m_bInfoFilled ? NULL : m_pInfo);
if (UMC_OK != umcRes)
return m_bEndOfStream ? UMC_ERR_END_OF_STREAM : UMC_ERR_NOT_ENOUGH_DATA;
if (!m_pInfo->m_pDecSpecInfo)
// populate decoder specific info with sequence header with all extensions
m_pInfo->m_pDecSpecInfo = new MediaData(seqEnd - m_lCurPos);
m_pInfo->m_pDecSpecInfo->SetDataSize(seqEnd - m_lCurPos);
memcpy(
m_pInfo->m_pDecSpecInfo->GetDataPointer(),
m_pBuf + m_lCurPos,
m_bInfoFilled = true;
m_CurFrame.iBufOffset = m_lCurPos;
m_lCurPos += 4;
m_bSeqSCFound = true;
m_bFrameBegFound = true;
AssignAbsPos(m_CurFrame.iBufOffset);
else
{ // we are after reposition, just wait for new sequence header or I-picture
while (m_lCurPos < m_lLastBytePos - 5 &&
!(IS_CODE(&m_pBuf[m_lCurPos], 0xb3)) &&
!(IS_CODE(&m_pBuf[m_lCurPos], 0x00) && ((m_pBuf[m_lCurPos + 5] >> 3) & 0x07) == I_PICTURE))
m_lCurPos++;
if (m_lCurPos >= m_lLastBytePos - 5)
// Find begin of frame
if (!m_bFrameBegFound)
Ipp32s savePos = m_lCurPos;
while (m_lCurPos < m_lLastBytePos - 3 && !IS_CODE_3(&m_pBuf[m_lCurPos], 0xb3, 0xb8, 0x00))
m_lCurPos++;
if (m_bEndOfStream)
return UMC_ERR_END_OF_STREAM;
CutInterval(m_PrevSample, m_LastSample, m_pBuf, savePos, m_lCurPos, m_lLastBytePos, m_bPureStream);
m_lLastBytePos -= m_lCurPos - savePos;
m_lCurPos -= m_lCurPos - savePos;
return UMC_ERR_NOT_ENOUGH_DATA;
// Find picture start code
if (!m_bPicSCFound)
while (m_lCurPos < m_lLastBytePos - 5 && !IS_CODE(&m_pBuf[m_lCurPos], 0x00))
m_lCurPos++;
VideoStreamInfo *pVSI = (VideoStreamInfo *)m_pInfo->m_pStreamInfo;
if (!m_bInfoFilled && MPEG2_VIDEO == pVSI->stream_type && PROGRESSIVE != pVSI->interlace_type)
umcRes = ParsePictureHeader(&m_pBuf[m_lCurPos], m_lLastBytePos - m_lCurPos, m_bInfoFilled ? NULL : m_pInfo);
return umcRes;
// set time stamps
AssignTimeStamps(m_lCurPos);
// set frame type
m_CurFrame.SetFrameType((buf[m_lCurPos + 5] >> 3) & 0x07);
m_lCurPos += 6;
m_bPicSCFound = true;
// Find begin of the next frame
if (m_bFrameBegFound && m_bPicSCFound)
while (m_lCurPos < m_lLastBytePos - 3 && !IS_CODE_4(&m_pBuf[m_lCurPos], 0xb3, 0xb7, 0xb8, 0x00))
m_lCurPos++;
if (!m_bEndOfStream)
ippsZero_8u(&m_pBuf[m_lLastBytePos], 4);
m_lLastBytePos += 4;
m_lCurPos = m_lLastBytePos;
// Frame found, check type and playback rate
m_CurFrame.uiSize = m_lCurPos - m_CurFrame.iBufOffset;
if (IsSampleComplyWithTmPolicy(m_CurFrame, m_dRate))
m_CurFrame.CopyTo(frame[0], m_pBuf);
// prepare for next frame
m_CurFrame.dPTS = m_CurFrame.dDTS = -1.0;
bFound = true;
else
CutInterval(m_PrevSample, m_LastSample, m_pBuf, m_CurFrame.iBufOffset, m_lCurPos, m_lLastBytePos, m_bPureStream);
m_lLastBytePos -= m_lCurPos - m_CurFrame.iBufOffset;
m_lCurPos = m_CurFrame.iBufOffset;
// start finding next frame
m_bFrameBegFound = false;
m_bPicSCFound = false;
return UMC_OK;
To fix the interlaced type problem I modified it this way:
Status umcRes;
while (!bFound)
if (!m_bSeqSCFound)
if (!m_bInfoFilled)
m_lCurPos++;
seqEnd++;
memcpy(
m_pBuf + m_lCurPos,
m_lCurPos += 4;
if(m_bSeqSCFound && m_bPicSCFound)
else
m_lCurPos++;
m_lCurPos++;
if (m_bEndOfStream)
if (!m_bPicSCFound)
m_lCurPos++;
return umcRes;
// set time stamps
// set frame type
m_lCurPos += 6;
m_lCurPos++;
bFound = true;
else
return UMC_OK;
Anonymous2
Naveen_G_Intel
We have fixed this issue in IPP 7.0 Update 3 release, its available now to download.
For more information, refer to forum announcement - Intel IPP 7.0 update 3 is shipping as of March 28, 2011.
Naveen Gv
