Undefined reference to ippsMalloc
bibi88
Until now, I've worked with IPP using only the image processing library ("ippi... functions"). Because I work my OS is 64 bits, I've included -lippsem64t, but however, if I want to use ippsMalloc, the compilator throws a "Undefined reference to ippsMalloc". How could I check if this function has well been linked please?
Thanks in advance!
bibi88
I have found the mistake: the manual shows on page 557 the function ippsMalloc(size), which doesn't exist. However, it works well with ippsMalloc_8u(size)...
Vladimir_Dudnik
Again, not sure what version of IPP you are talking about, the online documentation provides you correct example of Using the function ippsMalloc
Vladimir
Chao_Y_Intel
Bibi88,
It is right, no function calls ippMalloc, it only has function called ippsMalloc_8u, ippsMalloc_16s, ippsMalloc_8s, etc. You need to choose one according to the data type you need.
Chao
bibi88
Chao_Y_Intel
In that URL, the example code, itused _8u function (ippsMalloc_8u), 'ippsFree'function do not have the type.
Ipp8u* pBuf = ippsMalloc_8u(8*sizeof(Ipp8u));
if(NULL == pBuf) // not enough memory
ippsFree(pBuf);
Chao
bibi88
Chao_Y_Intel
thanks for pointing it out. This is typo in that example, and need to be fix. It needs either use 'ippsMalloc_8u' function, or 'ippMalloc' ( no 's' here) from IPP core libraries.
Chao
