Unresolved external symbol at linkage
patmetheny
I'm using IPP v5.0.
I'm trying to compilethe Intel Echo Cancellation sample in Visual.NET2003.
In DOS mode,thebatch file builds it successfully.
But in VS, I'm getting:
LNK2019: unresolved external symbol _ippGetCpuClocks @ 0 referenced in function _measure_start
I've added the library file which includes(ippcore.lib)to the linking options
( the lib file can be found by the linker, but for some reason it cannot find the function...)
Message Edited by PatMetheny on 12-07-2005 08:57 AM
Vladimir_Dudnik
did you include "ippcore.h" file in your source file where this function called from? Actually, I have no idea, never face such problem...
Vladimir
patmetheny
Yes, I've included "ippcore.h", otherwise I guessit wouldn' t have compiled.
Thanks anyway.
Vladimir_Dudnik
could you also check that ippcore.lib you use are from IPP v5.0 for IA? In previous libraries this function has name ippCoreGetCpuClocks.
Vladimir
