Usage of GFpECSignSM2
Jim1990
Hi, is there any sample for "GFpECSignSM2"? For below syntax which parameter is optional or not and which value should pass to them?
I'm a .NET developer and green hand in C language.
Now I have the SM2 private key file and I need to sign a message with SM2 algorithm.
Thanks!!!
ShanmukhS_Intel
Thank you for posting on Intel Communities.
We would like to inform you, the links shared by you contain the type of parameters to be passed to the function, as you have requested for the type of parameters. Regarding your query, Could you please be more specific with respect to your query or add more details so that we could help you in assisting the same?
Shanmukh.SS
Jim1990
Thanks for your reply.
Now I have a "sign.sm2" file which contains private key, I'd like to know how to pass it in function "GFpECSignSM2"
or does the Intel SDK support below private key for SM2 algorithm?
Sincerely,
ShanmukhS_Intel
Thanks for sharing the details. We will get back to you soon with an update.
Shanmukh.SS
ShanmukhS_Intel
Hi Jim,
We are discussing your issue internally. We will get back to you soon with an update.
Apologies for the delay in response.
Shanmukh.SS
Jim1990
ShanmukhS_Intel
Hi Jim,
Thank you for your feedback. As mentioned earlier, we have provided your feedback to the relevant team and they are looking into it. At this moment there is no visibility when it will be implemented and available for use.
Could you please let me know if we can go ahead and close this case?
Shanmukh.SS
ShanmukhS_Intel
Hi Jim,
We have not heard back from you. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Shanmukh.SS
