Use IPP static library in Windows Kernel Mode
gongyi_l_
How to use IPP  static library in Windows Kernel Mode ?
and where  can  I download  a sample of driver develop?
Ying_H_Intel
Hi Gongyi L,
What kind of function from IPP you want to use in kernel model?
You may refer to the sample and user guide in
https://software.intel.com/en-us/articles/intel-integrated-performance-primitives-intel-ipp-intel-ipp-linkage-models-quick-reference-guide
to build your program.
Ying H.
Intel IPP Consulting
gongyi_l_
such as      ippStaticInit(),ippiResizeYUV422_8u_C2R;
 What  kind of   ipp-linkage-models can use in window kernel model?
below is my code :     ( error LINK2019: unresolved external symbol  _ippStaticInit()……)
#include <ntddk.h>
#include "ipp.h"
#pragma comment( lib, "ippcoremt" )
typedef struct _DEVICE_EXTENSION {
    PDEVICE_OBJECT pDevice;
} DEVICE_EXTENSION, *PDEVICE_EXTENSION;
#define SymLinkName L"\\DosDevices\\Global\\DebugDemo"
#pragma code_seg("INIT")
NTSTATUS CreateDevice (
        IN PDRIVER_OBJECT    pDriverObject)
    NTSTATUS status;
    PDEVICE_OBJECT pDevObj;
    PDEVICE_EXTENSION pDevExt;
    UNICODE_STRING devName;
    UNICODE_STRING symLinkName;
    RtlInitUnicodeString(&devName,L"\\Device\\DebugDemo");
    status = IoCreateDevice( pDriverObject,
                        sizeof(DEVICE_EXTENSION),
                        &devName,
                        FILE_DEVICE_UNKNOWN,
                        0, TRUE,
                        &pDevObj );
      ippStaticInit();
    if (!NT_SUCCESS(status))
        return status;
Ying_H_Intel
Hi Gongyi,
I send your private message and include one driver developer sample.  You may refer to it.
Ying
levicki
Valued Contributor I
If I am not mistaken, ippStaticInit() function is deprecated and removed in newer IPP versions. You should call ippInit() instead.
