6845 Discussions
Using Intel Integrated Performance Primitives Signal Processing in Microsoft* C# .NET*
melanieipp
I've implemented a Signal demodulation for communications simulations. I'm using the Intel IPP Signal Processing functions in C#. That is, I'm making calls into the IPP C-style unmanaged code from a C# managed code. The function I wrote is working, but every once in a while it crashes the demodulation function crashes my application and it shuts down the application. I was wondering if it could be a segmentation fault, out of memory error, or threads interlocking? I'm not sure where to start with the problem.
Naveen_G_Intel
We have sample code which demonstrates how to use Intel IPP when developing applications in the Microsoft C# environment. Includes wrapper classes to support Intel IPP string manipulations, image, signal processing, color conversion, cryptography, data compression, JPEG, matrix and vector math.
http://software.intel.com/en-us/articles/intel-integrated-performance-primitives-code-samples/
Also, we have an article about IPP usage in .NET framework along with step by step information about creating wrapper. Please refer to http://software.intel.com/en-us/articles/using-intel-math-kernel-library-and-intel-integrated-performance-primitives-in-the-microsoft-net-framework/
Naveen Gv
