Using LUTPalette
costelha1
I have an RGB555 image and want to apply a LUT operation on it, in order to get an image with only a few colors. I.e., I want to get a one plane image where in each (x,y) I get one index in a predefined range.
From what I've read, I can segment an RGB555 image using the LUTPalette function, since this origin image as 16bits. To do this probably I will have to set nBitSize=16 and use the mod=16u8u_C1R. I now that the RGB555 is a 3 channel image, but I don't see why it won't work if I just pretend it is a one channel, 16 bits image.
Well, what I'm asking is for clarification on these assumptions, and I would appreciate much if someone could post a piece of code illustrating the use of this function.
Thanks in advanced for your help.
Bitwise, I'm using IPP 5.0 beta.
Hugo
Vladimir_Dudnik
there is recommendation from our expert:
you can do like this
Code:
pTable = ippsMalloc_8u(1 << 15);
// prepare LUT table
for (i = 0; i < (1 << 15); i ++)
    pTable = something;
// applay LUT
ippiLUTPalette_16u8u_C1R(pSrc, srcStep, pDst, dstStep, roiSize, pTable, 15);
Vladimir
costelha1
Thanks, I think that was exactly what I was looking for. I'll try it as soon as possible.
Hugo Costelha
