VC 1 encoding and decoding
suchethanswaroop
Hi all,
Could some one please tell me where to find the parameter file for encoding VC1 . I couldnt find the parameter file for VC 1 . ( The other parameter files such as h264, avs, h263 etc are found atipp-samples\audio-video-codecs\application\umc_video_enc_con).
I built the VC1_dec c++ file ( present in :audio-video-codecs/codec ). But this didnt result in the formation of exe file. It gave some build errors. Could some one enlighten me about VC 1 decoding ?
Suchethan
Chao_Y_Intel
Hi Suchethan,
Attached is an example for VC encoder parameter file.
The project files at /audio-video-codecs/codec will create some .lib file, not executable file. You can build the solution file at audio-video-codecsapplicationsimple_player to get one simple player exe file.
Chao
suchethanswaroop
Quoting - Chao Y (Intel)
Hi Chao,
Thank you soo much for the reply :). I successfully encoded the vc1 seq using "umc_video_enc_con.exe" and decoded using " simple_player.exe".
but could u please tell me why H.264 has a separate exe file to decode ( umc_h264_dec_con.exe)and not others ?
Suchethan
Hi Suchethan,
Chao
Chao_Y_Intel
Hi Suchethan,
umc_h264_dec_con.exe is an additional application which provide more accurate benchmark result than simpleplayer. Unfortunately, other codecs do not have such application. You need to use simpleplayer as an example.
Chao
suchethanswaroop
So, Can i separate the code from simple player for VC 1 or is it too complicated ( I am new to C++) ?
Suchethan
Hi Suchethan,
Chao
