VS2012 and IPP 8.
Claude_G_
I've install ipp and the integration with VS 2012 doesn't work....
VS Premium 2012
Intel C++ Composer XE 2013 SP1 8.0.0.083
In VS 2012 in one project :
Project - Properties - Intel Perf Lib set to single threaded static
Project - Properties - General - Composer XE is not listed.....
left click on project - Composer -
The only option is c++ compiler, and if I select it I got the message:
No Intel C++ compiler for platform(s) in the project(s).
If I go to Tools - Option
Intel Composer XE - > No Intel C++ compiler
I have also VS 2008 and everything seems OK.
As anyone faced this previously?
Gennady_F_Intel
yes, there are a number of known issues wit integration in VS2012. We are working on these issues. You need to explicitly add the list of libraries you need for linking the application.
Claude_G_
Thank you for the comment.
Is there a way to set VS2012 to use the Intel compiler?
Or command line is the only option.
Sergey_K_Intel
I got VS2012 and "Intel® C++ Composer XE 2013 SP1 Update 2 Integration for Microsoft* Visual Studio* 2012, Version 14.0.1290.11".
Though, the integration works. May be you need to re-install... what the Composer do you have?
Sergey
Claude_G_
Thank you Sergey,
I reallly want to know the difference, because I reinstall 3 or 4 times, with VS2012, without VS2008, only intel64, etcc...
Here is the paste for the info in VS2012:
Microsoft Visual Studio Premium 2012
Version 11.0.61030.00 Update 4
Microsoft .NET Framework
Version 4.5.50938
Installed Version: Premium
LightSwitch for Visual Studio 2012   04941-004-0043007-02218
Microsoft LightSwitch for Visual Studio 2012
Office Developer Tools   04941-004-0043007-02218
Microsoft Office Developer Tools
Team Explorer for Visual Studio 2012   04941-004-0043007-02218
Microsoft Team Explorer for Visual Studio 2012
Visual Basic 2012   04941-004-0043007-02218
Microsoft Visual Basic 2012
Visual C# 2012   04941-004-0043007-02218
Microsoft Visual C# 2012
Visual C++ 2012   04941-004-0043007-02218
Microsoft Visual C++ 2012
Visual F# 2012   04941-004-0043007-02218
Microsoft Visual F# 2012
Visual Studio 2012 Code Analysis Spell Checker   04941-004-0043007-02218
Microsoft® Visual Studio® 2012 Code Analysis Spell Checker
Portions of International CorrectSpell™ spelling correction system © 1993 by Lernout & Hauspie Speech Products N.V. All rights reserved.
The American Heritage® Dictionary of the English Language, Third Edition Copyright © 1992 Houghton Mifflin Company. Electronic version licensed from Lernout & Hauspie Speech Products N.V. All rights reserved.
Visual Studio 2012 SharePoint Developer Tools   04941-004-0043007-02218
Microsoft Visual Studio 2012 SharePoint Developer Tools
ASP.NET and Web Tools   2012.3.41009
Microsoft Web Developer Tools contains the following components:
Support for creating and opening ASP.NET web projects
Browser Link: A communication channel between Visual Studio and browsers
Editor extensions for HTML, CSS, and JavaScript
Page Inspector: Inspection tool for ASP.NET web projects
Scaffolding: A framework for building and running code generators
Server Explorer extensions for Windows Azure Web Sites
Web publishing: Extensions for publishing ASP.NET web projects to hosting providers, on-premises servers, or Windows Azure
Intel® C++ Composer XE 2013 SP1   Package ID: w_ccompxe_8.0.0.083
Intel® C++ Composer XE 2013 SP1 beta Integration for Microsoft* Visual Studio* 2012, Version 14.0.1248.11, Copyright © 2002-2013 Intel Corporation. All rights reserved.
* Other names and brands may be claimed as the property of others
PHP Tools for Visual Studio   1.8.4704
PHP Tools extend Visual Studio with a set of features to build PHP applications more efficiently. It makes code more readable, easier to navigate, and clean.
PreEmptive Analytics Visualizer   1.0
Microsoft Visual Studio extension to visualize aggregated summaries from the PreEmptive Analytics product.
SQL Server Data Tools   11.1.20627.00
Microsoft SQL Server Data Tools
Claude_G_
Maybe one note I forgot, I couldn't used the online installation for some reason, it jams in the middle....
I used the full installation (offline).
Sergey_K_Intel
This is pretty old composer version. Are any of updates available to you? Intel Software Manager works? What does it say? Though it can be not an IPP issue, but Composer's.
Try to ask at http://software.intel.com/en-us/forums/intel-c-compiler forum.
Sergey
Claude_G_
Thanks Sergey,
Yah, I realized that after I post the last message, I update, de-install everything and re-install the last update. I got the same version than you and it still doesn't work.
I will post in the compiler forum.
