6845 Discussions
Video_Enc_Con.cpp Encoder Problems of IPP 5.2 Samples
allenx
I put all needed files to a directory,
and Compile thoese files in VS.net 2003 to make Video_Enc_Con.cpp Encoder
in IPP 5.2 Samples, instead of using "build32.bat"
, and I have IPP 5.2, Intel Compiler 10.0 Intel Math Kernel 9.0
, and then
when I encode mpeg files to H264 or m4,
Read few frames! and return me "Can't Read Y or U or V Frames"? What's the Problem?
i use command like this : video_enc_com h264 -w 320 -h 240 -f 30 -i My.mpeg -o a.avi
Thanks your reading
Best Regards!
Allenx
allenx
Thanks a lot, after that & read your reply,
I execute again like this :
encoder h264 -w 352 -h 288 -f 30 -b 30000 -i a.yuv or cif-o a.264
then it works! but m2 & m4 use fewer time to encode with less precision.
And I have another question is about ,
I just used VC.NET 2003 Compiler,
Intel Compiler would be better than 2003?
because I encoded h264 using 10~15 frames per second on my Pentuiem-M 1.5G RAM 512MB,
Is there any other way to let the encoding process be more faster?
Increase to 30~60 frames per second,
because I have to encode 30~60 frame/sec uploading to Server computer in realtime.
in the future, I may embedded my program into Altera NioS II Board
Allenx
Best Regards.
