- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Intel and Programmer's
Webinar topic:
What are the Differences Between Intel Itanium Architecture and Intel Extended Memory 64 Technology?
When:
Tuesday, November 16th at 1:00 p.m. PST
How to register:
Visit the Programmers
This session will give you the basics you need to target a ported application to either an established Intel Itanium processor-based platforms or to the new Intel EM64T-based platforms. This session will give you a key tip on how to spot likely porting issues.
Covered topics:
Mixing and matching Intel generated objects with those from GCC* or Microsoft*
Key differences between the Intel Compiler functionality for Itanium-based systems and Intel EM64T-based platforms
Targeting an application for code or address spaces larger than 2GB
Optimizations that can be gained by using Intel Compiler on Intel EM64T-based platforms
New SSE3 instructions available on Intel EM64T-based platforms
Key compiler optimization reports to help you understand applied optimizations
Message Edited by vdudnik on 10-26-2004 10:16 AM
링크가 복사됨
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
One of the placesyou could sign up and get updates in emails about upcoming web-casts events is
http://softwarecommunity.intel.com/ and set up an account with Intel Software Networks.
For the spring webcasts including DMIP, check this out: https://event.on24.com/event/36/88/3/rt/1/index.html?&eventid=36883&sessionid=1&key=D76A2FD29D7444AEC06765011A2D4953&sourcepage=register
Vladimir
