When should ippInit be called?
eos_pengwern
I have the following situation:
- to ease interopabilitywith C and Fortran code, I have encapsulated some of the IPP functions that I need to use in a C DLL with simplified interfaces.
- I'd now like to call IPP functions from this C DLL both from my main application, written in C++, and another DLL which is written in Fortran.
Do I just have to call ippInit() once from the main application when that opens, or do I need to make aseparate call to it from the Fortran DLL the first time that is used?
Also, does it make any difference whether the C DLL with simplified interfaces incorporates the IPP via static or dynamic linking?
Stephen.
igorastakhov
New Contributor II
Hi Stephen,
You should call ippInit() only once. Anyway nothing bad will happen if you call it from both main and F-dll - as both are running on the same CPU - the second call will do nothing.
We provide 3 types of libraries: dynamic (always threaded), threaded-static and non-threaded static. So the differnce between first 2 is the cost of 1st call - for dynamic linking it's always huge - and the size of your application (see IPP userguide). If you use the 3rd option - non-threaded static - you'll have single threaded IPP version without dependecy on libguide (dll that provides OMP support)
Igor
igorastakhov
New Contributor II
Hi Stephen,
Igor
eos_pengwern
Thank you Igor, that tells me exactly what I needed to know.
Stephen.
