Wiener filter
szakatszozo
Hi everybody,
I would like to restore a blurred image by constant object motion, useing the Wiener filter.
I can calculate the motion of the object in pixels in the captured image and also the angle of the motion. Is it possible to use the ippiFilterWiener to remove the blurr or that is only made for noise reduction?
What other possibilities I have with IPP functions?
Thank you in advance for the help,
zozo'
Vladimir_Dudnik
Yes, Wiener is for denoise operation. Unsharp filtering can help
/// another way, shorter. just one operation with unsharp mask
Ipp32f kernel[] = { -0.1667f, -0.6667f, -0.1667f, -0.6667f, 4.3333f, -0.6667f, -0.1667f, -0.6667f, -0.1667f };
IppiSize kernelSize = {3,3};
IppiPoint kernelAnchor = {1,1};
ippiFilter32f_8u_C1R( src+srcStep+1, srcStep, dst+dstStep+1, dstStep, dstSize, kernel, kernelSize,kernelAnchor);
Vladimir
szakatszozo
ok, i will try this, but i would need to construct the kernel in way to use the info about the motion bluri know apriori: the number of pixels it moves and the angle;
in my case the number of pixels is the important one, the movement itself is always a vertical one...
could you help me in this?
thank you,
zozo'
