calling C, Error spawning cl.exe
blaise_faugeras
I am using CVF under windows XP. I need to call C functions in my fortran code. As mentioned in the users guide I use the declaration (for eg)
EXTERNAL pushreal8array_
!DEC$ ATTRIBUTES C,REFERENCE :: pushreal8array_
in the fortran subroutine pushreal8 which calls the C function pushreal8array.
CVF gives me the following error message:
--------------------Configuration: modele - Win32 Debug--------------------
Compiling...
Does anybody know what to do? I can't figure it out.
I haven't got any C compiler, is this a problem?
Thank you,
Yours sincerely
B. Faugeras
Hereis an exempleof the fortran routine and the C function:
cccccccccccccccccccccccccccccccccccccccccccccccccccc
SUBROUTINE PUSHREAL8(x)
REAL*8 x, adr8buf(512), adr8lbuf(512)
INTEGER adr8ibuf,adr8ilbuf
LOGICAL adr8inlbuf
COMMON /adr8fbuf/adr8buf,adr8lbuf,
+ adr8ibuf,adr8ilbuf,adr8inlbuf
DATA adr8ibuf/1/
DATA adr8ilbuf/-1/
DATA adr8inlbuf/.FALSE./
c
IF (adr8ilbuf.ne.-1) THEN
adr8ilbuf = -1
adr8inlbuf = .FALSE.
ENDIF
IF (adr8ibuf.ge.512) THEN
adr8buf(512) = x
CALL pushreal8array(adr8buf, 512)
adr8ibuf = 1
ELSE
adr8buf(adr8ibuf) = x
adr8ibuf = adr8ibuf+1
ENDIF
END
static char adSid[]="$Id: adStack.c,v 1.5 10/.1/.1 .1:.3:.0 llh Exp $";
#include
#define ONE_BLOCK_SIZE 16384
#define CHUNK_SIZE 4096
/* The main stack is a double-chain of DoubleChainedBlock objects.
* Each DoubleChainedBlock holds an array[ONE_BLOCK_SIZE] of char. */
typedef struct _doubleChainedBlock{
struct _doubleChainedBlock *prev ;
char *contents ;
struct _doubleChainedBlock *next ;
} DoubleChainedBlock ;
/* Globals that define the current position in the stack: */
static DoubleChainedBlock *curStack = NULL ;
static char *curStackTop = NULL ;
/* Globals that define the current LOOKing position in the stack: */
static DoubleChainedBlock *lookStack = NULL ;
static char *lookStackTop = NULL ;
/* PUSHes "nbChars" consecutive chars from a location starting at address "x".
* Resets the LOOKing position if it was active.
* Checks that there is enough space left to hold "nbChars" chars.
* Otherwise, allocates the necessary space. */
void pushNarray(char *x, int nbChars) {
int nbmax = (curStack)?ONE_BLOCK_SIZE-(curStackTop-(curStack->contents)):0 ;
lookStack = NULL ;
if (nbChars <= nbmax) {
memcpy(curStackTop,x,nbChars);
curStackTop+=nbChars ;
} else {
char *inx = x+(nbChars-nbmax) ;
if (nbmax>0) memcpy(curStackTop,inx,nbmax) ;
while (inx>x) {
/* Create new block: */
if ((curStack == NULL) || (curStack->next == NULL)) {
DoubleChainedBlo ck *newStack ;
char *contents = (char*)malloc(ONE_BLOCK_SIZE*sizeof(char)) ;
newStack = (DoubleChainedBlock*)malloc(sizeof(DoubleChainedBlock)) ;
if ((contents == NULL) || (newStack == NULL)) {
DoubleChainedBlock *stack = curStack ;
int nbBlocks = 0 ;
while(stack) {
stack = stack->prev ;
nbBlocks++ ;
printf("Out of memory (allocated %i blocks of %i bytes) ",
nbBlocks, ONE_BLOCK_SIZE) ;
exit(0);
if (curStack != NULL) curStack->next = newStack ;
newStack->prev = curStack ;
newStack->next = NULL ;
newStack->contents = contents ;
curStack = newStack ;
} else
curStack = curStack->next ;
/* new block created! */
inx -= ONE_BLOCK_SIZE ;
if(inx>x)
memcpy(curStack->contents,inx,ONE_BLOCK_SIZE) ;
else {
int nbhead = (inx-x)+ONE_BLOCK_SIZE ;
curStackTop = curStack->contents ;
memcpy(curStackTop,x,nbhead) ;
curStackTop += nbhead ;
/* POPs "nbChars" consecutive chars to a location starting at address "x".
* Checks that there is enough data to fill "nbChars" chars.
* Otherwise, pops as many blocks as necessary. */
void popNarray(char *x, int nbChars) {
int nbmax = curStackTop-(curStack->contents) ;
lookStack = NULL ;
curStackTop-=nbChars ;
memcpy(x,curStackTop,nbChars);
} else {
char *tlx = x+nbChars ;
if (nbmax>0) memcpy(x,curStack->contents,nbmax) ;
x+=nbmax ;
while (x curStack = curStack->prev ;
if (x+ONE_BLOCK_SIZEmemcpy(x,curStack->contents,ONE_BLOCK_SIZE) ;
x += ONE_BLOCK_SIZE ;
} else {
int nbtail = tlx-x ;
curStackTop=(curStack->contents)+ONE_BLOCK_SIZE-nbtail ;
memcpy(x,curStackTop,nbtail) ;
x = tlx ;
/* LOOKs "nbChars" consecutive chars to a location starting at address "x".
* Activates the LOOKing position if it was reset.
* LOOKing is just like POPping, except that the main pointer
* remains in place, so that the value is not POPped.
* Further PUSHs or POPs will start from the same place as if
* no LOOK had been made. */
void lookNarray(char *x, int nbChars) {
int nbmax ;
if (lookStack == NULL) {
lookStack = curStack ;
lookStackTop = curStackTop ;
nbmax = lookStackTop-(lookStack->contents) ;
lookStackTop-=nbChars ;
memcpy(x,lookStackTop,nbChars);
} else {
if (nbmax>0) memcpy(x,lookStack->contents,nbmax) ;
x+=nbmax ;
while (x lookStack = lookStack->prev ;
if (x+ONE_BLOCK_SIZEmemcpy(x,lookStack->contents,ONE_BLOCK_SIZE) ;
} else {
lookStackTop=(lookStack->contents)+ONE_BLOCK_SIZE-nbtail ;
memcpy(x,lookStackTop,nbtail) ;
x = tlx ;
/****** Exported PUSH/POP/LOOK functions for ARRAYS: ******/
void pushreal8array_(char *x, int *n) {
pushNarray(x,(*n*8)) ;
Intel_C_Intel
It is better to ask this question on Intel Compiler forum.
Vladimir
