can't reinstall IPPs after ICC uninstall
Adriana_Gonzalez_Hai
I installed 32 and 64b version of the IPP libraries as well as the sample code library. I theninstalled ICC.
The ipp samples were not compatible with the version of icc so I unsinstalled icc.
The ipps were originally installed in /opt/intel/ipp/... directory. The ipp directory was gone after the icc uninstall. I tried to reinstall the ipp libs but I received the message:
If you want to reinstall the Intel IPP 6.1 Update 6 for Linux* on Intel 64
architecture
please uninstall current version and run install script again.
However, since the directory is no longer there, i cannot uninstall the library.
Is there a workaround for this issue?
many thanks...
PaulF_IntelCorp
Hello Adriana,
Requires a little research. Will get back to you. Note that on a Linux system the /opt/intel/ipp directory contains links to the actual files. The script might be looking at the actual files and not the links.
Paul
Chao_Y_Intel
After decompress the installation package, there are some rpm files. Possibly you can try to force RPM installation:
Go to rpm folder, use rpm to install the package:
#rpm --force -ivh --nodeps --ignorearch *.rpm
Chao
the rpm command above seems to have done the trick!
thanks for your help :)
Chao_Y_Intel
Glad to know it works. Welcome to here if you have questions/suggestions with Intel IPP.
Chao
