cannot compile IPP intel64
jing_w_
Using IPP IA32, compile passed and can run. But after using IPP Intel64, got following massage,
Error 7 error LNK2019: unresolved external symbol _ippGetStatusString@4 referenced in function _main C:\Users\jingwang\documents\visual studio 2013\Projects\Project_intel64\Project_intel64\Source_intel64.obj Project_intel64
Error 8 error LNK2019: unresolved external symbol _ippInit@0 referenced in function _main C:\Users\jingwang\documents\visual studio 2013\Projects\Project_intel64\Project_intel64\Source_intel64.obj Project_intel64
Error 9 error LNK2019: unresolved external symbol _ippGetEnabledCpuFeatures@0 referenced in function _main C:\Users\jingwang\documents\visual studio 2013\Projects\Project_intel64\Project_intel64\Source_intel64.obj Project_intel64
Error 10 error LNK2019: unresolved external symbol _ippiGetLibVersion@0 referenced in function _main C:\Users\jingwang\documents\visual studio 2013\Projects\Project_intel64\Project_intel64\Source_intel64.obj Project_intel64
Error 11 error LNK1120: 4 unresolved externals C:\Users\jingwang\documents\visual studio 2013\Projects\Project_intel64\Debug\Project_intel64.exe Project_intel64
I have set the similar path in link/include/Executable of project.
If using intel64, any other option need to add?
Jing
Sergey_K_Intel
Hi Jing,
Could you check that your project properties/C/C++/Advanced/Calling Convention property is set to "__cdecl (/Gd)".
Not "stdcall" and not "fastcall".
Sergey
Gennady_F_Intel
Jing, my two cents -  have you linked with 64 bit IPP's libraries?
jing_w_
hi Sergey,
I check the "project properties/C/C++/Advanced/Calling Convention " is set to "__cdecl (/Gd)".
I am using Microsoft Visual Studio 2013, is it possible this Microsoft Visual Studio 2013 only support 32bits operation?
Sergey Khlystov (Intel) wrote:
Hi Jing,
Sergey
jing_w_
Hi Gennady,
I have linked the 64bits IPP lib as following
add project Property -> C/C++ -> General -> Executable Directories -> C:\Intel\Composer XE 2013 SP1.083\redist\intel64\ipp\;
add project Property -> C/C++ -> General -> Include Directories -> C:\Intel\Composer XE 2013 SP1.083\ipp\include\;
add project Property -> C/C++ -> General -> Library Directories -> C:\Intel\Composer XE 2013 SP1.083\ipp\lib\intel64\;
if I modify above "intel64" to "ia32", it can work.
Gennady_F_Intel
Hello Jing,
I don't have 2013 version available, but I used your test1_0.cpp file and create MVSC 2010 solution for 64 bit. See at this project into attachment.
here are the output and build log files. the version of IPP - 8.1
ippIP AVX (e9) 8.1.0 (r41650)
SSE    :Y
SSE2   :Y
SSE3   :Y
SSSE3  :Y
SSE41  :Y
SSE42  :Y
AVX    :Y
AVX2   :N
OS Enabled AVX :Y
AES            :N
CLMUL          :Y
RDRAND         :N
F16C           :N
Press any key to continue . . .
Creating "Debug\test.unsuccessfulbuild" because "AlwaysCreate" was specified.
1>MessageBuildingWithCompiler:
1>  Building with Intel(R) C++ Compiler XE 14.0
1>ClCompile:
1>  ***** ClCompile (x64 - Intel C++)
1>  test1_0.cpp
1>Link:
1>  xilink: executing 'link'
1>Manifest:
1>  Deleting file "Debug\test.exe.embed.manifest".
1>LinkEmbedManifest:
1>  tmp.vcxproj -> C:\_tmp\_Forums\ipp_u507095\Debug\test.exe
1>FinalizeBuildStatus:
1>  Deleting file "Debug\test.unsuccessfulbuild".
1>  Touching "Debug\test.lastbuildstate".
1>
1>Build succeeded.
Sergey_K_Intel
There is something special in how MS x64 linker generates the names of external functions in object files. I don't remember exactly, but the
suppose that you have the following program:
extern "C" {
    void _stdcall foo();
int main()
    foo();
The "foo" is declared like IPP function should be declared. In VS2013 on x64 you will get:
1>Source.obj : error LNK2019: unresolved external symbol foo referenced in function main
For win32 the diagnostics is:
1>Source.obj : error LNK2019: unresolved external symbol _foo@0 referenced in function _main
This difference in function name decorations in object file is reflected in IPP libraries. For win32 flavor (win32 libs) the names are decorated as _<function_name>@<stack_size>. If you look into library files with
 > dumpbin /exports ippcore.lib | find "ippGetStatusString"
you will see "_ippGetStatusString@4" for win32 libs and "ippGetStatusString" for intel64 libs.
You can do the same experiments in your environment. Make sure your "x64" project is consistent.
Sergey
Gennady_F_Intel
and here is the VS2010 solution
jing_w_
Hi Gennady,
This issue is fixed. Because my project set to win32, but x64. After set to x64, it can works.
Jing
jing_w_
Hi Sergey,
Thank you of reminding me about this.
Jing
extern "C" {
int main()
    foo();
Sergey
Gennady_F_Intel
perfect, thanks for the update.
