driver installer failing
Dheej
I keep getting this issue when I update my graphics driver even when i already rebooted my laptop five times is there a way to update my drivers
help please
laptop is acer extensa 215-55
The installer failed to properly install this driver. Please restart your system and try again. If the problem persists please contact Intel Customer Support for further help. System error code: 1072 - "The specified service has been marked for deletion." Installer exit code: 1
AlHill
You are in the wrong forum.
So the Intel customer support technicians can have more information about your system, download and run the Intel System Support Utility (https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- ) for Windows. Select all data categories and then have it generate a report. Next, have the tool Save the report to a text file (don't try to use the Submit capability; it doesn't work). Finally, using the Drag and drop here or browse files to attach dialog below the edit box for the body of your response post, upload and attach this file to the response post.
[CoPilot is a virus, W11 is a keystroke logger, all from MicroSlop]
