function returns wrongly!
calimero
I am implementing a class under visual studio using Intel library functions and basically there is Black function that calls Correlation function. When I output the results in the Correlation function, it is ok but when I output the results after the call in the Black function, then the output is wrong. I will appreciate if someone can help me?
In the header file of Colour.h:
private:
Ipp32fc* pZero;
In the cpp file:
Colour::Colour(void)
pZero = NULL;
void Colour::allocate(int nLenOr)
pZero = ippsMalloc_32fc(5*len);
void Colour::Black(Ipp32f *samples, Ipp32f *s, int sampleSize, int *Size)
Correlation(pSignal, pInvZero, 2*len-2, 3*nFFTlenSegment-5, pZero );
for(int r=0; r<5*len-7; r++)
stream<<< "\\t"<.re<<"\\t"<.im<
void Colour::Correlation (Ipp32fc *sample1, Ipp32fc *sample2, int len1, int len2, Ipp32fc *pSamplesOut)
int sumlen = len1+len2-1;
for(int rr = 0; rr< sumlen; rr++)
pSamplesOut[rr].re = pSamplesOut[rr].re;
pSamplesOut[rr].im = pSamplesOut[rr].im;
stream<<<"\\t"<
