have problem in using the ipp samples
kodaku
I have problem in using the ipp samples in evc.I use Sitsang board and it seems that the examples is STANDARD SDK oriented,not for SITSANG SDK ,then what specific configuration there should be if I wanna use ipp on Sitsang board? when I compile the attached program,I met with such problems as follows:
Linking...
casestudyshell.obj : error LNK2019: unresolved external symbol ippsConv_16s referenced in function qmain
ARMV4IRel/Casestudy.exe : fatal error LNK1120: 1 unresolved externals
Error executing link.exe.
Casestudy.exe - 2 error(s), 0 warning(s)
Ying_S_Intel
Dear Customer,
Are you using Intel IPP for PCA? Which compiler do you use? It seemed to mea tool compatibility issue. Could you please submit an issue with details to Intel Premier Support where we handle technical support for Intel Software Products including Intel IPP, so we can take a look at your case and find the root cause.
Ying S
Intel IPP Support
