6847 Discussions
high context switching when multi threading VC1 encoder
vanista
I have an issue with the VC1 encoder from IPP sample code. I don't think the issue is directly related to this codec though.
If in a same process I run a number of encoding threads that exceeds the number of CPU cores on the host, the number of contex switches jumps over 1 million per second (compared to 3000 per second in normal maximum load conditions) and the CPU usage suffers from 50% system overhead.
I'm using IPP v5.3.1.062
I was able to isolate some parts of the code which trigger the c-switch bomb, for one I identified the ippAddC function to be in cause.
From what the doc says this function is thread optimized, so I wonder if there could be a conflict between this and linux kernel thread handling
vanista
As additionnal info, it's exactly two unique function calls in intra mb encoding which trigger the problem (ippiSubC_16s_C1IRSfs and ippiAddC_16s_C1IRSfs)
umc_vc1_enc_picture_sm.cpp:1362
 //only intra blocks:
for (blk = 0; blk<6; blk++)
roiSize.height = 8;
roiSize.width = 8;
IPP_STAT_START_TIME(m_IppStat->IppStartTime);
_own_Diff8x8C_16s(128, pCurMBData->m_pBlock[blk], pCurMBData->m_uiBlockStep[blk], roiSize, 0);
IPP_STAT_END_TIME(m_IppStat->IppStartTime, m_IppStat->IppEndTime, m_IppStat->IppTotalTime);
STATISTICS_START_TIME(m_TStat->FwdQT_StartTime);
IntraTransformQuantACFunction(pCurMBData->m_pBlock[blk], pCurMBData->m_uiBlockStep[blk],
DCQuant, doubleQuant);
STATISTICS_END_TIME(m_TStat->FwdQT_StartTime, m_TStat->FwdQT_EndTime, m_TStat->FwdQT_TotalTime);
umc_vc1_enc_picture_sm.cpp:1449
 for (blk=0;blk<6; blk++)
STATISTICS_START_TIME(m_TStat->InvQT_StartTime);
IntraInvTransformQuantACFunction(pCurMBData->m_pBlock[blk],pCurMBData->m_uiBlockStep[blk],
TempBlock.m_pBlock[blk],TempBlock.m_uiBlockStep[blk],
STATISTICS_END_TIME(m_TStat->InvQT_StartTime, m_TStat->InvQT_EndTime, m_TStat->InvQT_TotalTime);
_own_Add8x8C_16s(128, TempBlock.m_pBlock[blk],TempBlock.m_uiBlockStep[blk],roiSize,0);
Meanwhile, I've fixed my issue by writing custom unoptimized replacement function for those two cases.
Chao_Y_Intel
Hello vanista,
How are you linking with Intel IPP libraries? Internal threading within IPP functions (ippAddC ) are only enabled when you link with IPP dynamic library or threaded static libraries. If you are using static library, it will include none threaded functions.
Chao
