how to compile DLL for Java application using Visual C++ 2012
Samuel_L_1
based on IPP java sample, I generated C header.  With c file and c header, i want to compile them in Visual C++.
But it gives a lot error, most of them is type mismatch. even jclass class is not correct.
so who can help me how to compile dlls for java application.
SergeyKostrov
Valued Contributor II
>>... I have native c file and I generated header file, but when i compile them using Visual C++, it give me errors. Samuel, Could you post a compilation output with these errors? Also, what version of Microsoft compiler ( IDE ) do you use?
