how to use ippiHaarClassifierInit_32f
风__付
hi,
when i use opencv and with  ipp 2018
and  found ippiHaarClassifierInit_32f would return -8 error. code like this.
#ifdef HAVE_IPP
    int can_use_ipp = !out->has_tilted_features && !out->is_tree && out->isStumpBased;
    if( can_use_ipp )
        int ipp_datasize = cascade->count*sizeof(out->ipp_stages[0]);
        float ipp_weight_scale=(float)(1./((orig_window_size.width-icv_object_win_border*2)*
            (orig_window_size.height-icv_object_win_border*2)));
        out->ipp_stages = (void**)cvAlloc( ipp_datasize );
        memset( out->ipp_stages, 0, ipp_datasize );
        ipp_features = (CvRect*)cvAlloc( max_count*3*sizeof(ipp_features[0]) );
        ipp_weights = (float*)cvAlloc( max_count*3*sizeof(ipp_weights[0]) );
        ipp_thresholds = (float*)cvAlloc( max_count*sizeof(ipp_thresholds[0]) );
        ipp_val1 = (float*)cvAlloc( max_count*sizeof(ipp_val1[0]) );
        ipp_val2 = (float*)cvAlloc( max_count*sizeof(ipp_val2[0]) );
        ipp_counts = (int*)cvAlloc( max_count*sizeof(ipp_counts[0]) );
        for( i = 0; i < cascade->count; i++ )
            CvHaarStageClassifier* stage_classifier = cascade->stage_classifier + i;
            for( j = 0, k = 0; j < stage_classifier->count; j++ )
                CvHaarClassifier* classifier = stage_classifier->classifier + j;
                int rect_count = 2 + (classifier->haar_feature->rect[2].r.width != 0);
                ipp_thresholds = classifier->threshold[0];
                ipp_val1 = classifier->alpha[0];
                ipp_val2 = classifier->alpha[1];
                ipp_counts = rect_count;
                for( l = 0; l < rect_count; l++, k++ )
                    ipp_features = classifier->haar_feature->rect.r;
                    //ipp_features.y = orig_window_size.height - ipp_features.y - ipp_features.height;
                    ipp_weights = classifier->haar_feature->rect.weight*ipp_weight_scale;
            returnVal =  ippiHaarClassifierInit_32f((IppiHaarClassifier_32f*)out->ipp_stages,
                (const IppiRect*)ipp_features, ipp_weights, ipp_thresholds,
                ipp_val1, ipp_val2, ipp_counts, stage_classifier->count);
            if(returnVal < 0 )
                break;
        if( i < cascade->count )
            for( j = 0; j < i; j++ )
                if( out->ipp_stages )
                    ippFree( (IppiHaarClassifier_32f*)out->ipp_stages );
            cvFree( &out->ipp_stages );
#endif
but if i change ipp version to 6.1
the code just like this
#ifdef HAVE_IPP
    if( can_use_ipp )
            if( ippiHaarClassifierInitAlloc_32f( (IppiHaarClassifier_32f**)&out->ipp_stages,
                ipp_val1, ipp_val2, ipp_counts, stage_classifier->count ) < 0 )
                break;
                    ippiHaarClassifierFree_32f( (IppiHaarClassifier_32f*)out->ipp_stages );
#endif
it would work well. the different between above code  is ippiHaarClassifierInitAlloc_32f and ippiHaarClassifierInit_32f
so i'm not sure what's the problem with 2018 ipp. please help, or any one can send me a example code to use ippiHaarClassifierInit_32f
thank 's a lot.
Ruqiu_C_Intel
The function ippiHaarClassifierInitAlloc_32f has been removed from IPP9.0. As workaround, please use ippiHaarClassifierGetSize + ippMalloc + ippiHaarClassifierInit_32f to replace the function ippiHaarClassifierInitAlloc_32f .
Ruqiu
风__付
Ruqiu
thank you
and  can you send me an example for how to use  ippiHaarClassifierGetSize + ippMalloc + ippiHaarClassifierInit_32f
i could not find such things from the documentation
