iplRotate and Rotate_Image
ram200200
Hi
I am trying to use a Rotate_Image function , which uses the iplRotate function.
However, it seems that iplRotate consumes memory that can't be freed later, when
the function finishes. (iplDeallocate doesn't help either).
1)Do you have an advanced iplRotatetate without that problem?
2)Do you have an Rotate_Image image function which enables the
interpulations options:
IPL_INTER_LINEAR IPL_INTER_NN IPL_INTER_CUBIC
but frees all its used memory when it ends?
Dan
Rob_Ottenhoff
Quoting - ram200200
Hi
Dan
Hi Dan,
I don't know the Rotate_Image and iplRotate functions, but I have never experienced any problems with using ippiRotate directly. Perhaps you can check the implementations of Rotate_Image and iplRotate ?
Sorry if this doesn't help.
Rob
ram200200
Quoting - Rob Ottenhoff
Hi Dan,
Rob
Dear Rob
I have tried to rotate an Input_Xsize*Input_Ysize unsigned image, without any ROI .
However, I receive a blank image (in Output_Data).
1)Can you tell me why?
2)Should stride be Input_Xsize or 1?
Thanks, Dan
ippiGetRotateShift(xcenter, ycenter, (double)angle, &xshift, &yshift);
// IppiRect srcROI,dstROI;
srcROI.x=srcROI.y=dstROI.x=dstROI.y=0;
srcROI.width=dstROI.width=Input_Xsize;
srcROI.height=dstROI.height=Input_Ysize;
//IppiSize srcSize,dstSize;
srcSize.width=dstSIZE.width=Input_Xsize;
srcSize.height=dstSIZE.height=Input_Ysize;
ippiRotate_8u_C1R(Input_Data, srcSize,
Input_Xsize, srcROI,
Output_Data, Input_Xsize, dstROI,
(double)angle, (double)xshift+dx, (double)yshift+dy, interpolate);
Rob_Ottenhoff
Quoting - ram200200
Dear Rob
Thanks, Dan
Hoi Dan,
I cannot see anything obvious. Some points: you should use the stepsize as stride. Not the width of the images. The stepsize is returned when you create your image. And are you sure the xcenter, ycenter, dx,dy variables are correct ? Here is the code that works for me : it rotates an image around its centerpoint:
.. part of a wrapper class::Rotate(angle, pDest)
{ // I left out some details to handle the case when the source and dest do not have the same resolution
IppiSize roiSize = { GetWidth(), GetHeight() };
IppiRect roiRectSrc = { 0, 0, GetWidth(), GetHeight() };
IppiRect destRect = { 0, 0, pDest->GetWidth(), pDest->GetHeight() };
double xShift, yShift;
ippiGetRotateShift(GetWidth()/2, GetHeight()/2, angle, &xShift, &yShift);
ippiRotate_8u_C1R(m_pImageBuffer, roiSize, m_StepSize, roiRectSrc,
pDest->m_pImageBuffer, pDest->m_StepSize, destRect,
angle, xShift, yShift, IPPI_INTER_CUBIC | IPPI_SMOOTH_EDGE);
Hope this helps,
Rob
ram200200
Hoi Dan,
Hope this helps,
Rob
Hi Rob
Thanks for your efforts. I found the reason of the error-
Although the stride should have been the Image_SizeX as I thought, my interp value was yielded from the IPL system,
and I simply had to change it to the IPPI constants.
BTW -
Is there a way to avoid the need of adding all the IPPI dlls to wherever I want toput my executable code?
(even at different computers, without the IPPI on them)
all the best
Dan
Rob_Ottenhoff
Quoting - ram200200
BTW -
all the best
Dan
Hi Dan,
There is a redistributable installer in [IPPDIR]toolsruntimeinstaller
Rob
ram200200
Hi Dan,
Rob
Thanks Rob.
Can you briefly direct me how to use it, or where should I lear about it
(I will use only the ippiRotate_8u_C1R function)
Dan
Rob_Ottenhoff
Quoting - ram200200
Thanks Rob.
Dan
Hi Dan,
The runtime installer has a readme file.
Rob
