ipp 2017 update 2 Histogram buffer size issue
Stella_Y_
I've encountered a  problem of calculating the image histogram when using the latest ipp static library(2017 update 2)
The issue happened when I call the ippiHistogramGetBufferSize function.I needed to calculate the buffer size before doing histogram for single-float type image, but this function return  0 in sizeBuffer . Then it will crash my histogram calculating code. I doubted it was the potential bug for this function.
const int WIDTH = 5;
const int HEIGHT = 5;
const int nbins =5;
int nLevels [] = {nbins +1};
ippiSize roi = {WIDTH,HEIGHT};
int sizeHistObj,sizeBuffer;
ippiHistogramGetBufferSize(ipp32f, roi, nLevels, 1, 1, &sizeHistObj,&sizeBuffer);
I've tired ipp8u,ipp16u,ipp16s type, they were ok, although return a big memeory size refer to ipp16u or ipp16s.
Please somebody come to help .
Igor_A_Intel
Hi Stella,
1) you don't analyze status code after IPP function execution - with your code it indicates "wrong step"
2) you've forgotten that step is in bytes - therefore you should multiply it by sizeof( float )
below is a bit corrected code:
#include <stdio.h>
#include "ipp.h"
#define nBins 5
int main(){
    int w;
    float *hh1;
    const int WIDTH = 6;
    IppiSize roi = {WIDTH, HEIGHT};
    IppStatus sts;
    int nLevels[] = { nBins+1 };
    Ipp32f lowerLevel[] = {0};
    Ipp32f upperLevel[] = {255};
    int sizeHistObj;
    int sizeBuffer;
    IppiHistogramSpec* pHistObj;
    Ipp8u* pBuffer;
    Ipp32u pHistVec[nBins];
 /* fill the data */
//    ippInit(); /* rudiment, exists for compatibility with "old" IPP versions */
    hh1 = (float*)ippsMalloc_32f( HEIGHT * WIDTH );
    for( w = 0; w < HEIGHT * WIDTH; w++ ){
        hh1 = (float)3.5 * w;
//get sizes for spec and buffer
    ippiHistogramGetBufferSize( ipp32f, roi, nLevels, 1/*nChan*/, 1/*uniform*/, &sizeHistObj, &sizeBuffer );
    pHistObj = (IppiHistogramSpec*)ippsMalloc_8u( sizeHistObj );
    pBuffer = ippsMalloc_8u( sizeBuffer );
//initialize spec
    ippiHistogramUniformInit( ipp32f, lowerLevel, upperLevel, nLevels, 1, pHistObj );
// calculate histogram
    sts = ippiHistogram_32f_C1R( hh1, WIDTH * sizeof( Ipp32f ), roi, pHistVec, pHistObj, pBuffer );
    if( ippStsNoErr != sts ){
        printf( "%s\n", ippGetStatusString( sts ));
        return( -1 );
    for( w = 0; w < nBins; w++ ){
        printf("bin = %d contains %d values\n", w, pHistVec );
    ippsFree( hh1 );
    ippsFree( pHistObj );
    ippsFree( pBuffer );
    return 0;
it works correctly:
bin = 0 contains 15 values
bin = 1 contains 15 values
bin = 2 contains 0 values
bin = 3 contains 0 values
bin = 4 contains 0 values
Press any key to continue . . .
regards, Igor
Igor_A_Intel
Hi Stella,
how the bufferSize==0 can crash you code? Could you be more specific and/or provide a reproducer? The size of buffer equal to zero means that this function doesn't need any intermediate buffer for histogram calculation, nothing more.
regards, Igor
Stella_Y_
Thanks Igor, Now I understand the bufferSize==0 is normal behavior. But I can't run the histogram calculation in my program after the initialization. Below is my code:
/* fill the data */
ippInit();
float* hh1 = (float*)malloc( 5 * 6 * sizeof(float) );
for(w =0;w<30;w++)
     hh1 = (float)3.5*w;
IppStatus sts;
{ const int nBins = 5;
 int sizeHistObj;
 int sizeBuffer;
 Ipp8u* pBuffer;
 ippiHistogramGetBufferSize(ipp32f, roi, nLevels, 1/*nChan*/, 1/*uniform*/, &sizeHistObj,&sizeBuffer);
//initialize spec
sts = ippiHistogram_32f_C1R( hh1, WIDTH, roi, pHistVec, pHistObj, pBuffer );
 for(i = 0;i<nBins;i++)
     printf(" %u \n",++*pHistVec);
So when I print out the bin value of the histogram, it turns out the wrong number which even greater than the total number of the array.
Jing_Xu
I tested your code, didn't find any problem.
How did you compile the code? Please try to use the following command to build the code.
gcc test.c -o test -I<IPP_INCLUDE_PATH> <IPP_LIB_PATH>/libippi.a <IPP_LIB_PATH>/libipps.a <IPP_LIB_PATH>/libippcore.a
B.t.w., you don't need to call ippInit() anymore. It will be called automatically.
Igor_A_Intel
Hi Stella,
#include <stdio.h>
#include "ipp.h"
#define nBins 5
int main(){
    int w;
    float *hh1;
    IppStatus sts;
    int sizeHistObj;
    int sizeBuffer;
    Ipp8u* pBuffer;
 /* fill the data */
//initialize spec
        return( -1 );
    ippsFree( hh1 );
    return 0;
it works correctly:
regards, Igor
Stella_Y_
Great Thanks, Igor and Jing.
Now I find out the root cause of the program failure, in the ippiHistogram_<mod> function the srcStep parameter should be set in byte. when I modified the code as Igor suggested, the program ran correctly then.
regards,
Stella
