ipp_sample build fail
dfgreth5_s_
My OS is windows 7,  l build ipp_sample,some error occur
Not searching for unused variables given on the command line.
CMake Error at C:/Sample/ipp-samples.7.1.1.013/builder/FindIPP.cmake:93 (message):
Intel(R) IPP was not found (required)!
l has created environment variable named IPPROOT that points to the root directory of my intel IPP installation.
C:\Program Files\Intel\Composer XE 2013\ipp
please help me,thanks
dfgreth5_s_
who can help me
Sergey_K_Intel
Hi!
Are sure about "Program Files"? Usually Composer is set up in "Program Files(x86)".
Sergey
dfgreth5_s_
yes,my os is win7 32 bit
Pankaj_T_
i was facing the same problem as above. for the resolution of the above problem please comment the line in "FindIPP.cmake" file where it check that IPP_FOUND is defined or not and rum the cmake again . Now it works properlly.
dfgreth5_s_
but l can't modify this file named "FindIPP.cmake". do l need modify it?
SergeyKostrov
Valued Contributor II
I think you need to review if IPP environment variables are set instead of modifying that make file.
