6846 Discussions
ipp sample programs in audio-video-codecs fail to compile with Intel compiler
abalk
I am using the intel 10.1 compiler on Linux to build the ipp samples in audio-video-codecs. Everything compiles except for the last few things in the build32.sh script. these are
******* audio_codecs FAILED
******* audio_codec_con FAILED
******* simple_player FAILED
******* umc_video_enc_con FAILED
******* umc_h264_dec_con FAILED
******* umc_dv_dec_con FAILED
The error is the same on all:
ld: skipping incompatible /home/abalk/intel/ipp/5.3.1.062/ia32/sharedlib/libippdc.so when searching for -lippdc
ld: cannot find -lippdc
make: *** [/home/abalk/ipp/ipp-samples/audio-video-codecs/_bin/linux32_icc101/simple_player] Error 1
Why is this library incompatible? Any suggestions would be great.
Vladimir_Dudnik
Please sumbit your issue to Intel Premier Support.
Vladimir
abalk
Just wondering, "ld" is the gnu linker. Doesn't the intel compiler have it's own linker?
Or does the intel compiler run the gnu linker by design ?
Vladimir_Dudnik
Intel compiler is responsible for generating optimized object code from your source code. To build a final application you need to involve some linker (usually, linker is part of development environment available for platform, VC200x on Windows or gcc on Linux)
Vladimir
