ippGetCpuFreqMhz segmentation fault
Grant_S_2
I get a segmentation fault when I call ippGetCpuFreqMhz().
Ubuntu 12.04 LTS
Intel® Core™ i7-4610M CPU @ 3.00GHz × 4
static libraries
Netbeans IDE 7.4
gcc -o dist/Debug/GNU-Linux-x86/timingtestipp build/Debug/GNU-Linux-x86/src/CicDownSamp.o build/Debug/GNU-Linux-x86/src/TimingTestIpp.o -L../lib -L/opt/intel/ipp/lib/intel64 -lsidekiq__x86_64 /opt/intel/ipp/lib/intel64/libippcc.a /opt/intel/ipp/lib/intel64/libippch.a /opt/intel/ipp/lib/intel64/libippcore.a /opt/intel/ipp/lib/intel64/libippcv.a /opt/intel/ipp/lib/intel64/libippdc.a /opt/intel/ipp/lib/intel64/libippi.a /opt/intel/ipp/lib/intel64/libipps.a /opt/intel/ipp/lib/intel64/libippvm.a -lpthread -lm -lrt -ldl
Let me know if you need more.
Grant Schmick
Igor_A_Intel
Hi Grant,
pMhz is not initialized in your case, correct code is below:
 int *pMhz;
 int iCpuMhz;
 pMhz = &iCpuMhz;
 ippStatus = ippGetCpuFreqMhz(pMhz);
or simpler one:
 int iCpuMhz;
 ippStatus = ippGetCpuFreqMhz(&iCpuMhz);
regards, Igor
Grant_S_2
Also:  IPP_VERSION_STR "8.2.2"
Language: C
Jonghak_K_Intel
Hi Grant,
Can I see how you declare a variable for and call ippGetCpuFreqMhz() in your code?
Thank you
- Jon
Grant_S_2
Jon,
Here's the relevant code:
#define READ_CPU_FREQ
#ifdef READ_CPU_FREQ
int *pMhz;
int iCpuMhz;
#endif
    // read the processor speed
    iCpuMhz = *pMhz;
#endif
The fault occurs on the function call; if I comment it out, it doesn't occur.
Grant
Igor_A_Intel
Hi Grant,
 int *pMhz;
 int iCpuMhz;
 pMhz = &iCpuMhz;
or simpler one:
 int iCpuMhz;
regards, Igor
