ippi20.lib
Deleted_U_Intel
Hi
i am trying to run "c:program filesintelipp40examplesippiSample" by compiling in Latest Visual Sturio . Net. I got the "Fatal error Link1181, Can not open input file "ippi20.lib". When i check the flolder at
"c:program filesitemipp40lib", there is no "ippi20.lib. Any suggestions
armand vergil
Intel_C_Intel
you should set in .NET studio the right path to the import libraries. The all IPP import libraries are located in stublib folder. In lib folder onlystatic libraries are located.
Vladimir
Intel_C_Intel
yes,it isgreat. But if youdid notstartMSVC .NET studio from this commandprompt session, your settings has no effect to .NET studio.
Vladimir
Intel_C_Intel
There should not be any magic. If you have folder stublib and this folder contains ippi20.lib file and you set upyour MSVC settings in right way there should not be any problem.
Vladimir
