ippiAlphaComp Ouput Buffer
Scott_Danahy
I was wondering if it was possible to useippiAlphaComp in such a way that the output image is written to src2. Can the src2 and pDst parameters be the same image?
Thank you,
Scott
Chao_Y_Intel
Hello Scott,
The ippiAlphaComp do not have the inplace function. Additional copy function may needed if you want to src2/pDst are the same.
Chao
Scott_Danahy
I tested this and it worked when pSrc2 and pDest were the same pointers. Does the implementation really require them to be different?
Thank you,
Scott
