ippiDilateBorder_16u_C1R performance issues
P__Ella
In the previous ipp versions I used unique function for 3x3 morphology - ippiDilate3x3_16u_C1IR.
I'm now using ipp18. The new general function - ippiDilateBorder_16u_C1R with 3x3 mask is slower than the old one in about 17%.
Any ideas how to improve performances?
thanks,
Ella
Igor_A_Intel
Hi Ella,
could you provide a bit more info: image size, cpu, arch, OS, static/dynamic linking?
the best is the full output from ippGetLibVersion() function.
regards, Igor
P__Ella
Hi Igor,
This is the output of ippGetLibVersion() function:
    major        2018
    minor        0
    majorBuild    1
    build        56998
    targetCpu    "core...
    Name         "ippCore"
    Version         "2018.0.1 (r56998)"
    BuildDate    "Oct 10 2017"
I runs the function with 2048x2048 images.
I tested it with different computers, with different CPUs, windows 7 or 10.
Ella
P__Ella
Hi Igor,
Update - we've upgrade the ipp version to the following version:
    major        2018
    minor        0
    majorBuild    4
    build        60077
    targetCpu    core
    Name         ippCore
    Version       2018.0.4 (r60077)
    BuildDate   Aug 15 2018
This upgrade improved the running time dramatically, and now the dilate function runs faster in my computer (Core(TM) i7-9820HQ). However, in the target computer, the upgrade did not affect the running time, and it still slow.
The target CPU is Xeon E5-6280 b2
Ella
Pavel_B_Intel1
Hi Ella,
could you clarify: do you use DilateBorder as deprecated Dilate algorithm (without operations on border) or with border operations?
In any way thank you for the issue reporting, we will investigate this case.
Pavel
P__Ella
Hi Pavel,
I send to the function an ROI of the image and use ippBorderInMem.
thanks,
Ella
