ippiFilter + offset?
Evgeniy_Kosmin
Im trying to implement Emboss filter through ippiFilter, but I cannot find a way to use an offset value.
Imaging software like Photoshop or GIMP allows setting three parameters for custom filters: convolution matrix, scale and offset.
Is there something like "ippiFilter + offset" I can use for my purposes?
Evgeniy
Chao_Y_Intel
For the offset, do it mean that it only process part of the image? For ippiFilter_ function, you can set the pSrc to start of that part, and also the function set the ROI size for that part.
Chao
Evgeniy_Kosmin
Hi Chao,
Thanks for your reply.
I'm attaching two screenshots from Photoshop to illustrate what I mean.
"Offset" is not a buffer offset.
By applying kernel to source image we have some sum for one destination pixel. This sum is divided by divisor and placed to destination buffer and there is no way to add some fixed offset to this result. Some effects like emboss from my screenshots requires constant to be added.
In all imaging software offset is supported and I wonder is there any stuff for this in IPP?
Evgeniy
Chao_Y_Intel
Hi Evgeniy,
After calling the filter, can this be done with calling ippiAddC_ ? That will add one const value to the image.
Chao
Evgeniy_Kosmin
No, it cannot be done.
ippiFilter_ will truncate negative values to zeros and effect will be wrong.
Let's say, for example, I need to implement color invertion with ippiFilter_.
In general it can be done with {0, 0, 0, 0, -1, 0, 0, 0, 0} 3x3 kernel + 255 offset.
Now ippiFilter_ gives me complete black destination buffer after applying kernel and there is nothing to add with constant.
Evgeniy
Chao_Y_Intel
Evgeniy,
Thanks for input. I am tracking this function as feature request.
Chao
Chao_Y_Intel
IPP 2107 added the following API, which can support this functionality now:
IPPAPI( IppStatus, ippiFilterBorderSetMode, (IppHintAlgorithm hint, int offset, IppiFilterBorderSpec* pSpec))
Chao
Eugene_K_1
Thank you, Chao.
I'll try it as soon as I can.
