ippiFloodFill freezes
Piotr_S_
I've discovered that ippiFloodFill_Range8Con_8u_C1IR function hangs on some images, e.g. for situation:
  • Seed(371, 149)  - in that point image has value 10
  • newValue = 0
  • minDelta = 10
  • maxDelta = 3
  • roiSize -> whole image
If needed I can send image on which function freezes.
Piotr S.
Chao_Y_Intel
Piotr,
Thanks for your report. Which versions of Intel IPP are you find the problem?  We will try to reproduce it.  The image will also help.
Thank you.
Chao
Piotr_S_
I'm using IPP 8.2 - please write where You want me to put the image
Piotr_S_
This situation occurs even if I changed ROI or seedValue is different from newValue and different from diff1 and diff2 - so it looks like 'never ending loop'.
Please write what is status of this issue
Piotr
Chao_Y_Intel
Piotr,
We could not reproduce the problem here.  If it works for you, could you attached your picture in the post?   When you reply, at the end of the post, it has option on "Attachments",  which can be used for adding your files.
Chao
Piotr_S_
Chao,
I'm sending *.zip file with software code and image.
Piotr
Chao_Y_Intel
Thanks, Piotr.  We will check it.
Chao
Chao_Y_Intel
Piotr.
Thanks for the code. We can reproduce this problem, and will fix it in future release.
Chao
Chao_Y_Intel
Piotr,
The fix is already available in the IPP 9.0 update 1 release. This release can be download from Intel Registration Center.
thanks for your report.
Chao
