ippiMalloc_32f_C3 Error in steps
sohrab
hi
ippiMalloc_32f_C3(4,4,&m_srcStep);
why the srcStep=64 where as it should be 48 (4*3*4) --> (pixel * depth * sizeof(float))
Sohrab
Vladimir_Dudnik
there is quote from ippi manual:
The function
ippiMalloc is declared in the ippi.h file. This function allocates a memory block aligned to a 32-byte boundary for elements of different data types. Every line of the image is aligned by padding with zeros in accordance with the pStepBytes parameter, which is calculated by the function ippiMalloc and returned for further use.
Vladimir
