ippiMalloc_64f?
ad_ms
is there some kind of 64f allocation? SqrIntegral needs a 64f image as output, and i'd be easier to allocate this directly instead of doing some 'magic tricks'.
thanks,
aydin
Vladimir_Dudnik
Hello aydin,
There is no ippiMalloc_64f function in IPP, but you may use ippiMalloc_32fc_C1 for SqrIntegral. Yes, this will require type casting for returned pointer. Is that too magically?
Vladimir
ad_ms
Hi Vladimir,
thanks for the answer, i was just wondering why there isn't such function, i thought maybe it's a bug in the documentation.and yes, its ok,even in delphi one can type-cast ;)
aydin
ad_ms
sorry, but i have another problem..the handler to the sqrintegral function gives back NIL always (or it doesnt give back anything at all)-- what i am doing wrong? i have triple-checked typos, and the structure is the same as for the other 200 functions. anyone any idea?
EDIT: ok, i found the function in the cv-libs..
Vladimir_Dudnik
I'm not so much familiar with Delphi programming. I remember there were severalDelphi related topics in this forum, you can take a look on some latest topics or you can search through forum for "Delphi" to see more
http://softwarecommunity.intel.com/isn/Community/en-US/forums/permalink/30233629/30233629/ShowThread.aspx#30233629
http://softwareforums.intel.com/ISN/Community/en-US/forums/permalink/30227695/30227695/ShowThread.aspx#30227695
http://softwareforums.intel.com/ISN/Community/en-US/forums/permalink/30225637/30225637/ShowThread.aspx#30225637
Vladimir
