ippiMalloc_8u_C1 returning wrong dstStep?
cedronius__anders
Im using ->
ippCore 2019.0.0 Gold (r59881)
On a mac
IppiSize dstSize = { 480, 270 };
Ipp8u* pDst = ippiMalloc_8u_C1(dstSize.width, dstSize.height, &dstStep);
ippiMalloc_8u_C1 returns dstStep=512 resulting in a 32 pixel black border on the right side of the picture.
However 480 is integer dividable by 32 (if that is a requirement to be 32 bytes aligned in the line by line stepping) and forcing dstStep to 480 works for all following processes I use and the black border is gone.
I use the example code ->
https://software.intel.com/en-us/ipp-dev-reference-resizeantialiasing-sample
Am I doing something wrong or is it a bug?
Thanks for helping.
/Anders
Andrey_B_Intel
Hi Anders.
IPP functions process images line by line using special SIMD instructions. Unfortunately these instructions have performance penalty when they load block of bytes that cross cache line.  Cache line is 64 byte length. So to try to achieve the better performance it is preferable to align lines of image on 64 byte. Also you can allocate memory using ippsMalloc_8u(dstSize.width*dstSize.height).
Thanks for your feedback.
