ippiMalloc causing error
bmeeder
I am getting errors when calling the malloc function. Currently I am using VC++.Net, and upon debugging and tracing through the call stack, there is a reference to address 0 in one of the OS malloc calls.
Is this a problem with the windows memory manager, or is it a problem with ippi?
I am only doing the following:
Ipp8u* buffer = ippiMalloc_8u_C1(80, 80, &stepSize);
where stepsize is just an integer.
Thank you.
Brendan Meeder
Vladimir_Dudnik
could you verify that stepsize is positive number?
Vladimir
