ippiMorphologyBorderInit
Adriaan_van_Os
Assuming that the actual declarations of  the various ippiMorphologyBorderInit flavours are correct, there are the following errors in the comments for the parameters
    roiWidth                 there is no roiWidth parameter but instead an roiSize parameter
    anchor                   there is no anchor parameter
    pState                   there is no pState parameter
Adriaan van Os
Chao_Y_Intel
Adriaan, this is also tracked to fix in the following releases.
regards,
Chao
