ippiMorphologyInitAlloc ?
xiangli
I need to use morphology operations from IPP. From the manual I got (page 8-13 of image and viedo library) it seems like I need to call ippiMorphologyInitAlloc.
Could someone help me pointing out where's wrong? The manual is short of any example on this function.
I also did a search in this forum.In Jan 2004 someone asked hot to use dilate&erode functions. There he/she didn't use ippiMorphologyInitAlloc at all.
So my second question is: is it necessary to call ippiMorphologyInitAlloc for all morphological operations?
Thanks a lot
// C code fragment that initialzes the morphology operation.
IppiSize seSize = { 3, 3 };
IppiPoint seAnchor = { 1, 1 }; // se's anchor point is the center. (0-based)
IppiMorphState** ppMorphState = NULL; // internal state structure.
IppStatus status;
// initialize morphology operation
status = ippiMorphologyInitAlloc(
imageDim, // int roiWidth.ROI width in pixels.
8u, // IppDataType dataType
1, // int channels. num of channels in image.
seSize, // size of structuring element.
seAnchor, // anchor point of the se.
ippiShapeCross, // structuring element shape.
NULL, // int* pElData not considered.
ppMorphState );
if( status != ippStsNoErr )
printf(" ippiMorphologyInitAlloc() failed with error %d: %s!", status, ippCoreGetStatusString( status ) );
// The error message is:
// ippiMorphologyInitAlloc() failed with error -8: Null pointer error!
Vladimir_Dudnik
could you please specify what version of IPP do you use and for which platform?
Vladimir
xiangli
Hi Vladimir,
Thanks for asking. I have solved the issue. I'm using Ipp ver. 4.1. It turned out to be that I don't need to call ippiMorphologyInitAlloc and I used dilate & erode directly.
Even though my code works now, I still noticed a difference between in-line and not-in-line dilate. Specifically, not in-line dilate gives larger spike artifacts along the border. ( I shunk the roi 6 pixels less than the image size already)
Anyway, glad to get IPP dilate&erode work.
Vladimir_Dudnik
Hi, it is great that you solved this issue, after consulting with engineers I can confirm that you choose correct way - no InitAlloc is required.
For example
Code:
/// Dilate a dot
IppStatus dilate( void ) {
   Ipp8u x[7*5];
   IppiSize roi = {7,5};
   ippiSet_8u_C1R( 0, x, 7, roi );
   x[2*7+3] = 1;
   roi.width = roi.width - 2;
   roi.height = roi.height - 2;
   return ippiDilate3x3_8u_C1IR( x+7+1, 7, roi );
  00 00 00 00 00 00 00
  00 00 01 01 01 00 00
Reagrding difference in inline and not-inline implementation I will pass this info to developers.
Vladimir
wuzweng
Hi!
You only need MorphologyInitAlloc for
ippiDilateStrip_Rect and ippiErodeStrip_Rect
ippiDilateStrip_Cross and ippiErodeStrip_Cross
ippiDilateStrip_Ellipse and ippiErodeStrip_Ellipse
ippiDilateStrip and ippiErodeStrip.
Vladimir_Dudnik
RIght, that's correct
Vladimir
Intel_C_Intel
IPP contains several morphology functions:
- erode/dilate with arbitraryvs rectangularSE. First are Erode/Dilate, Erode DilateErodeBorderReplicate, second areErode/Dilate3x3, FilterMin/Max, FilterMin/MaxBorderReplicate.
- functions for images with the border pixelsin memory (src and dst of different size) vs for images of the same size (with suffix BorderReplicate)
Alexander
xuhai
Recently, I am using the IPP morphology functions. I got 3 questions:
1. In ver 4.1, IPP is still using the elShape (ippiShapeRect, ippiShapeCross, ippiShapeEllipse and ippiShapeCustom) to define the shape of structuring element. But why in the ver 5.0 thereafter, IPP removed those shapes?
2. After removing the elShape, how can I use the MorphologyInitAlloc and MorphologyInit to initialize a structuring element?
3. How to use the function: MorphologyGetSize to obtain the size of morphollgy state structure? Can you provide some sample code (C++)?
Intel_C_Intel
In IPP 5.0 the interface of morphology function is changed. The reason was that modes (START, MIDDLE, END, WHOLE) had not really supported. Functions for Elliple and Cross worked completely the same as for arbitrary SE.
In IPP 5.0 there exist the functions for arbitrary SE and for special kernels:
ippiErode/Dilate - arbitrary SE, border pixels in the memory,
ippiErode/Dilate3x3 - 3x3 rectangular SE, border pixels in the memory,
ippiFilterMin/Max - rectangular SE, border pixels in the memory,
ippiMorphologyInitAlloc or
ippiMorphologyGetSize + malloc + ippiMorphologyInit - initialization of a structure for erode/dilate with arbitrary SE. Rectangular and symmetric SE are detected and are processed faster while eroding or dilating. Once initialized the structure can be used for many erode/dilate operations with the same SE
ippiErode/DilateBorder - morphology using preallocated structute, no border pixels in the memory,
Advanced morphology operationd (Open,Close,Tophat, Blackhat, Gradient), no border pixels in the memory,
Alexander
ippiFilterMin/MaxBorder - morphology with rectangular SE, no border pixels in the memory,
atari1984
Hi, I've got a little problem with ippiMorphologyInitAlloc and ippiMorphologyFree.
I allocate and initialize the IppiMorphState structure with ippiMorphologyInitAlloc. Then I proceed an erosion with ippiErodeBorderReplicate and a dilatation with ippiDilateBorderReplicate. Finally I try to free the memory used by the structure with ippiMorphologyFree. The problem is that my program crashes on the line where it tries to free the memory with ippiMorphologyFree.
Here is the code I use :
#define LARGEUR 384
#define HAUTEUR 288
typedef unsigned char BYTE;
void X::Y(BYTE ** Image)
IppiSize roiSize = {LARGEUR, HAUTEUR};
IppiMorphState* pState;
IppiPoint elAnchor;
Ipp8u*pMask;
IppiSize elSize;
elSize.height = 3;
elSize.width = 3;
elAnchor.x = 1;
elAnchor.y = 1;
pMask = (Ipp8u*)malloc(9*sizeof(Ipp8u));
pMask[0] = 1;
pMask[1] = 1;
pMask[2] = 1;
pMask[3] = 1;
pMask[4] = 1;
pMask[5] = 1;
pMask[6] = 1;
pMask[7] = 1;
pMask[8] = 1;
BYTE * Temp = (BYTE*)malloc(LARGEUR*HAUTEUR*sizeof(BYTE));
ippiMorphologyInitAlloc_8u_C1R(LARGEUR,pMask,elSize,elAnchor,&pState);
ippiErodeBorderReplicate_8u_C1R(*Image,LARGEUR,Temp,LARGEUR,roiSize,ippBorderRepl,pState);
ippiDilateBorderReplicate_8u_C1R(Temp,LARGEUR,*Image,LARGEUR,roiSize,ippBorderRepl,pState);
ippiMorphologyFree(pState);
free(Temp);
free(pMask);
Image is ok.
I use the IPP 5.1.
Can someone help me ?
Intel_C_Intel
ppMorph is the pointer to the variable for the pointer to the morphology structure. You should provide the memory where InitAlloc function could return it.
Change to
IppiMorphState* pMorphState; // internal state structure
&pMorphState );
Morphology with the rectangular kernel can be done by ippiFilterMin/Max(BorderReplicate) functions
Alexander
