ippiThreshold_Val_8u_C1IR
fzhe
Hi, there,
When I ran the following code,
Ipp8u img1[2][2]={0,1,2,3};
IppiSize sz1={2,2};
int stride = 2;
IppStatus s1 = ippiThreshold_Val_8u_C1IR(&(img1[0][0]),stride,sz1,0, 1, ippCmpGreaterEq);//ippCmpEq);
the return status (s1) is "ippStsNotSupportedModeErr" instead of ippStsNoErr.
Please advice on what is wrong with the code.
Fan
Vladimir_Dudnik
Fan,
if you'll look at description of this function in ippi manual you'll find that:
ippCmpOp
The operation to use for comparing pixel values and the threshold. Comparison for either less than or greater than can be used.
Vladimir
fzhe
Yes. I did try equal and greater than. Both of them produced that error status.
Vladimir_Dudnik
Really? I recommend you to submit issue report to Intel Premier Support
Please specify what version of IPP do you use and what platform, processor and OS.
Vladimir
fzhe
Tech support duplicated the problem and escalated it already. Since you gave me better answers than I got from tech-support, I want to try the forum too.
Thanks anyway.
Fan
Vladimir_Dudnik
Thanks you, we will check if it is wrong documentation issue or it is bug in function's implementation.
Vladimir
