ippirotate performance
Lamp
hi,
for some reason, i have to use ippirotate_8uC3R for a 4008 * 2672 RGB image, but this function will take more than 1 second to be processed...it's crazy.....
the CPU we are using is i7-2600, since ippirotate is not threaded, I guess it will run only on one Core.
is there any way to make it faster? or replace itby other functions?
SergeyKostrov
Valued Contributor II
It would be nice to see a test case. Could you provide it?
I think that performance impact is a combination of the following:
- 3 planes of4008x2672 each;
- some impact from performance of 'sin' and 'cos' functions used internallyby IPP, when angles are not
90, 180 or 270 degrees.You know how a new pixel's position is calculated: wx = x*cosA - y*sinA and
wy = x*sinA + y*cosA. So, you have 4 multiplicationsand2 adds/subs. In total, there are more than 192
million of FP operations to rotate an image for5 degrees, for example;
- a performance of aninterpolation algorithm.
I see more and more caseslike yours since sizes of imageshavedramatically increased.Nikon
recently announced a 36MP DSLR camera.Nokia announced a41MP smartphone. I don't know if Intel
Software Engineers evertested IPP with images like I mentioned above. I'm personally interested in
processing of32Kx32K images and larger.
By the way, I saw a singnificantly worse performance from Microsoft's ImagingAPI. It is simply impossible
to use!
Sergey
Lamp
it looks like differentinterpolation mode will effect the time a lot,
test on my laptop
IPPI_INTER_CUBIC 2.4 s
IPPI_INTER_LINEAR 0.7 s
IPPI_INTER_NN0.2 s
is there a big difference for thequality of returned image?
Thomas_Jensen1
Are you doing 90 degree angles, or any angles?
SergeyKostrov
to use!
Sergey
Lamp
any angles, between -1 and 1 for most of cases.
Lamp
The type "Matrix" contais the size of image and a byte array.
[cpp]Matrix^ IppBasicOperator::Rotate(Matrix^ source, double angle) { Matrix^ ans = gcnew Matrix(source->Size); IppiSize size = { source->Size.Width / source->PixelSize, source->Size.Height }; IppiRect roi = { 0, 0, source->Size.Width, size.height }; // Pin the matrix data pin_ptr pSource = &(source->GetBuffer()[0]); pin_ptr pDest = &(ans->GetBuffer()[0]); double xCenter = size.width / 2, yCenter = size.height / 2, xShift = 0, yShift = 0; ippiGetRotateShift(xCenter, yCenter, angle, &xShift, &yShift); int intep; if (angle == int::MaxValue) { // for debug test purpose intep = IPPI_INTER_NN; } else if (angle == int::MinValue) { // for debug test purpose intep = IPPI_INTER_CUBIC; } else { intep = IPPI_INTER_LINEAR; } if (source->PixelFormat == PixelFormat::Format24bppRgb) ippiRotate_8u_C3R(pSource, size, roi.width, roi, pDest, roi.width, roi, angle, xShift, yShift, intep); else ippiRotate_8u_C1R(pSource, size, size.width, roi, pDest, size.width, roi, angle, xShift, yShift, intep); return ans; }[/cpp]
Thomas_Jensen1
It appears that you do not use IPP memory allocation functions.
If I'm correct, there is a speed penalty when the image buffer does not start on a 16-byte boundary, and when its scanline width in bytes is not a multiple of 16 (padding at the right).
This is because Ipp uses SSE for most operations.
Use ippiMalloc_8u_C1(w,h,Step) to allocate your source and dest buffers. Step is an output value.
Thomas_Jensen1
It is not really required to use FP to rotate any angle. One can use a combination of skewing.
I do not know how Ipp implements rotation though.
SergeyKostrov
Quoting Lamp
//Pinthematrixdata
pin_ptrpSource=&(source->GetBuffer()[0]);
pin_ptrpDest=&(ans->GetBuffer()[0]);
I would look at these two assignments because in both cases smart-pointers are used.
Could you try something like:
__declspec( align( 16 ) ) Byte *pSource = ...
__declspec( align( 16 ) ) Byte *pDest = ...
Sergey
SergeyKostrov
It appears that you do not use IPP memory allocation functions...
They could be called in another method(s) of IppBasicOperator class.
I alsoagree that alignment of pointers to image datahas to be taken into consideration.
Sergey
Lamp
Quoting Lamp
//Pinthematrixdata
Sergey
I'll try toalign the data, but i don't know if it's possible... since it's a .NET application, have to pin it so GC will not move it in memory
regards
SergeyKostrov
Quoting Lamp
...for some reason, i have to use ippirotate_8uC3R for a 4008 * 2672 RGB image, but this function will take more than 1 second to be processed...
What software did you use to measure a performance of ippiRotate_8u_C3R function?
Did you do this in a Debug or Release configuration?
Sergey
