ippmInvert_m_32f segmentation fault
tharandur
Hello!
I've a problem with the function ippmInvert_m_32f. It works for me in Intel IPP 5.1, but I've update the Intel IPP to the actual version (5.3.4.080), and now, when the program calls the function, it give me a segmentation fault. I didn't change the program before to update de Intel IPP.
If you need some additional information, you only have to request it.
Thanks in advance!
Gennady_F_Intel
Hi tharandur.
This is unknown problem. I guess you are working on Linux.
Can you get us more details about your problem:
  1. What OS and CPU type are you working on?
  2. Can you give us the test case for reproducing the problem?
  3. How do link your application? ( static,dynamic or smth else)
--Gennady
