ippsDecodeLZO_8u performance issue
haixiao_j_
I found the API   ippsDecodeLZO_8u definition in Ippdc.h:
// Name: ippsDecodeLZO_8u
// Purpose: decompresses specified input buffer to output buffer, returns decompressed data length
// Arguments:
// pSrc pointer to input buffer
// srcLen input data length
// pDst pointer to output buffer
// pDstLen pointer to output data length variable. Initially contains output buffer length
// Return:
// ippStsNullPtrErr one of the pointers is NULL
// ippStsDstSizeLessExpected output buffer is too short for compressed data
// ippStsSrcSizeLessExpected input buffer data is not complete, i.e. no EOF found
// ippStsBrokenLzoStream ippsDecodeLZOSafe_8u detected output buffer boundary violation
// ippStsNoErr no error detected
If I passed the argument pDstlen (value = 0), the performance of ippsDecodeLZO_8u is very low. But If I passed the pDstlen (value = real output buffer length ), the performance is improved.
some misunderstanding:
  • I don't kown why the return code is always 'ippStsNoErr' when I passed the argument  pDstlen (value = 0), is right?
  • If IPP allows user call the API  ippsDecodeLZO_8u by passing the  argument   pDstlen (value = 0), why the performance is lower than I passed the real output buffer length . I think IPP will malloc additional buffer to support the situation that given argument pDstlen < decompressed_len. So this action willmake performance decline. Is right?
Haixiao
Chuck_De_Sylva
Are you linking with the single threaded or multithreaded libraries? Which version are you using?
haixiao_j_
Hi, sylva My applications linked with the single threaded libraries, and the IPP version is 7.1.0. Regards, Haixiao
SergeyKostrov
Valued Contributor II
>>...why the return code is always 'ippStsNoErr' when I passed the argument pDstlen (value = 0)... It looks like inconsistency with input parameters validation in the function. Ideally, it should look like: // Note: I skip all the rest verifications to simplify case ... if( pDst != NULL && pDstLen != 0 ) { // Some processing and exit from the function with ippStsNoErr } else { // pDst == NULL && pDstLen == 0 // or // pDst != NULL && pDstLen == 0 // or // pDst == NULL && pDstLen != 0 // Error in a value of input parameter and exit from the function with some error } ...
