ippsECCPGet reporting ippStsLnNegArg error
Sreekanth_M_Intel
Hi.
This is Sreekanth here. We are using an old version of IPP library, in prebuilt form from one of the other teams. (This other team is no more with Intel).
However, we have a crypto module in our platform that supports ECC operations. To this end, we are using this API, ippsECCPGet during the generation of  ECC keys.
When we use this API we see this error, ippStsLnNegArg, not sure why, though.
Could anyone please help?
Best Regards
Sreekanth Muralidharan
Gennady_F_Intel
follow the IPP Crypo manual (https://software.intel.com/en-us/ipp-crypto-reference-eccpget).  ippsECCPGet  doesn't return ippStsLnNegArg status. Could you give us a short example which we could build and check the problem?
Gennady_F_Intel
which version of IPP Crypto do you use?
Sergey_K_Intel4
Status code "ippStsLnNegArg" defined in IPP (but in crypto) and means Negative Argument in Ln function.
So, the situation is not clear. Let us know
1) version of IPP you are using
2) If you send short reproducer we can try to to detect the root case
Consider possibility to re-fresh the library
Sreekanth_M_Intel
Hi Gennady, Sergey,
Here is the version we use:
#define IPP_VERSION_MAJOR  2017
#define IPP_VERSION_MINOR  0
#define IPP_VERSION_UPDATE 1
#define IPP_VERSION_STR "2017.0.1"
Here is the snippet of the sample code which we use to call ippsECCPGet
IppsBigNumState *pPr;
IppsBigNumState *pa;
IppsBigNumState *pb;
IppsBigNumState *pgx;
IppsBigNumState *pgy;
IppsBigNumState *pO;
int cftr = 0;
// We initialize ECC context into ptr_ecc_state_context
IppStatus = ippsECCPGet(pPr, pa, pb, pgx, pgy, pO, &cftr, ptr_ecc_state_context);
printf("ippsECCPGet - %d\n", IppStatus);
Moreover, does this library send this error in case of a random number generator that might have not seeded with enough randomness?
Thanks for the quick response
