6822 Discussions
ippsTone_Direct_32f function to genrate sine phasor
rohitspandey
I am try to genrate quadrature phasor vector using ippsTone_Direct_32f
foffsin = foffCos + pi/2;
.ippStatsSin = ippsTone_Direct_32f(&v2[0],Np,1.0,foffsin,&ZeroPh1,ippAlgHintAccurate);
but the genrated phasor is inverse i.e instead sin(x) its gnerating sin(-x); If i try foffsin = foffCos - pi/2 the phasor is all zero.
Kindly let me know what could be wrong.
Rohit
rohitspandey
The problem was due to freq range in case of real is 0-0.5 instead of 0-1. But t perfromace of IPP function is not comparable with matlab. Kindly share some light on this
Rohit
SergeyKostrov
Valued Contributor II
Quoting rohitspandey
...Butperfromace of IPP function is not comparable with matlab...
Could you provide more technical details? Was it faster or slower?
rohitspandey
The EVM i.e difference betweenthe matlab numerical value and IPP results increases as the number of sample points are big like 10^5 and high...
Rohit
igorastakhov
New Contributor II
Matlab uses 64f internaly (maybe 80f) - so you can try ippsTone_Direct_64f with conversion to 32f
Igor
rohitspandey
Thats correct matlab uses double but if use the float variable in matlab the the results should be same.But you will see this is not the case. I tried comparing the tone generation with direct sin and cos function and compared the results are different.Tone generation function is not correctly working
Direct implementation
ippC = ippsVectorSlope_32f(&v1[0],Np,0,foff);
ippA = ippsCos_32f_A24(&v1[0], &v2[0], Np);
ippB = ippsSin_32f_A24(&v1[0], &v3[0], Np);
tone genrator
ippStatsSin = ippsTone_Direct_32fc(pbuf,Np,1.0,foff,&ZeroPh,ippAlgHintAccurate);
Used following matlab code
ang=2;%4,6,8,....
in=single([0:1:len-1]);
ph = single(pi/ang);
xI = single(cos(ph.*in));
xQ = single(sin(ph.*in));
And compared the result among them and with matlab. The direct implementation exactly matches matlab while tone genrator has rounding error and it grows as number of sample
Kindly verify the tone genrator implementation Function.
Rohit
jeffc111
Using your example, try this:
xl1 = single(cos(single(single(pi/2)*(0:100000))));
xl2 = single(cos(pi/2*(0:100000)));
plot(xl1-xl2)
The error will grow linearly with length (on average).
Now try this:
xl1a = single(cos(single(single(pi/2)*mod(0:100000,4))));
hold on;
plot(xl1a-xl2, 'g')
The error will be consistent and very small.
Cos and Sin are VERY sensitive to precision when their value is near zero, and since the cos(x) = cos(mod(x,2*pi)), the loss of significant digits to the right of the decimal has a huge impact on the output.
The main point is that your single precision matlab code is not a good reference.
