6845 Discussions
ippsc.lib did not found even Intel(R) Parallel Studio XE 2015 is installed
vijendra_k_
I had installed trial version of Intel(R) Parallel Studio XE 2015 for Windows.
But it does not contain ippsc.lib in C:\Program Files (x86)\Intel\Composer XE 2015\ipp\lib\ia32 folder
how do i get ippsc.lib ?
Sergey_K_Intel
Look here for the solution: https://software.intel.com/en-us/forums/topic/531021
vijendra_k_
Hi sergey,
Thanks for reply. The link you suggested worked for me.
I got ippsc.lib in directory.
I had downloaded sample applications from
https://software.intel.com/en-us/articles/code-samples-for-intel-integrated-performance-primitives-intel-ipp-library-71
but when i tried to build sample application speech-codecs, its gives me linking errors as
ippcore_l.lib
ipps_l.lib
ippsc_l.lib
ippvm_l.lib not dound
Why it is trying to find lib with _l , my all libs are present without _l ???
Sergey_K_Intel
"_l" library name suffix is pre-8.0 version feature. After that, the names were changed to "ipp<lib code>mt.lib". "mt" here means not multi-threading, it is just Microsoft-like library naming style. So, the static libs are all "*mt.lib", dynamic export libraries are "ipp<library code>.lib" without "mt".
You need to find in 7.1 samples how command line to linker is generated and change *_l.lib to *mt.lib.
Ying_H_Intel
Just for your information.
The "latest" legacy samples like speech codec, audio-video codec etc. are available at the URL.  IPP 8.0 sample page:
https://software.intel.com/en-us/articles/code-samples-for-intel-integrated-performance-primitives-library
Ying
